Using PPS to configure PCM5242
Other Parts Discussed in Thread: PCM5242, PCM5142, PCM5141, SRC4392
Hi team,
1. I used PPS(home audio) to control PCM5242 EVM,but I can only select PCM5142 from frameworks. does it work if I select PCM5141?
2. I connect a simple circuit to test whether I can control the volume,but It dosen't work,I had writen the configuration file of SRC4392 ,using USB input.
w e0 01 38
w e0 03 01
w e0 05 19
w e0 06 01
3. My target is mixing the tone generator and original audio output , How can I realize this function by connecting these modules in PPS ,could you show me your connecting method in PPS?
