Hi I am using the PCM4222 TDM slave mode and the is a one BCK period delay on the data, the FMT1 and FMT0 are set correct( if you set them both Hi you get another delay). In master mode the data is correct - no delay. The data is also correct in double speed mode (slave) - no delay.
I need a solution to transmit the data in slave mode at normal speed sampling mode with no delay
Tom
