A customer will use PCM5121. They have question about PCM5121 datasheet as below.
Their question is about load impedance, in PCM5121 Datasheet, page 9, it say the load impedance is >5KΩ, like below
But in page1, it say the load can down to 1kΩ,and in page 7, also has such data below.
a) Why the data is different in datasheet? When use 1kΩ load, Can PCM5121A output 2.1Vrms? They also hope TI can provide the diagram of Load impedance vs output voltage.
b) What is the tolerance of output voltage( in above table, only typical value:2.1 Vrms, They need the min and max data).
Akio Ito
