Part Number: PCM1851A
Hello
I am trying to design a circuit for testing an audio card. The idea is to take the audio jack (from DUT) and plug it into the test circuit instead of a 2x10 Watt Speakers
I am planning to use a PCM1851A from TI for digital conversion and then take the FFT of the incoming audio.
The audio circuit amplifer works at 12V and sends differential analog signal for both left / right speakers (Left_p, Left_n, Right_p, Right_n)
I need a way to scale down the differential audio signal to an acceptable range and change it to a single ended signal before feeding it to the PCM1851A.
Can you please give me some pointers for this operation?
thank you very much
rifo
