When RX1 is used as the input terminal, then signal goes through SRC block, and Port B is used as the output terminal. There would be no I2S signal output through this path. (Port B is configured as slave mode)
When the signal is processed in other paths, it would be normal, such as if SRC block is not used.
So customer think the SRC block should be not working.
Any suggestion on this case?
Thanks.
