• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Audio Converters » Audio Converters Forum » 2 USB-MODEVM driver issues
Share
Audio Converters
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    How to determine the power at output of modulator from DAC back-off level
    Posted 23 hours ago
    by Habeeb Ur Rahman Mohammed
    Customers often ask how they can determine the power at the output...
    DAC Essentials: What’s with all this glitch-ing?
    Posted 5 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 7 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
This question is answered
Rob B
Posted by Rob B
on Oct 05 2010 09:50 AM
Prodigy10 points
I have 2 issues of equal importance that I could really use some help with regarding USB-MODEVM interface drivers (both are in reference to the TLV320AIC3xEVM-PDK):
Issue 1:
Installing the USB-MODEVM drivers on a Windows 7 / Vista platform to fulfill an upcoming requirement.  I've tried d/l'ing and installing the USBfirmwareV0203.zip found in this forum, and they did not work, or I'm doing something wrong.  I've poked around a bit and can't seem to locate anything else right now, so I'm sort of stuck.  All I need is the USB-MODEVM communication with a host PC, I have an already working board+app which uses this USB communication with a host PC running XP.   When I attempt to hook this system to the Vista machine (stand-in for Win 7), it asks for location of the drivers.  I point it to the unzipped folder contents of the above mentioned zip and it still says the drivers were not installed correctly.
Any help would be appreciated - I'm guessing it is something very simple/basic that I am missing or doing incorrectly.
Issue 2:
I have two laptops which I'd like to have these drivers installed on working on for Win XP.  On one of the laptops, the drivers install correctly.  I can see that the device appears Device Manager as both an NI-VISA USB Device (USB-MODEVM) and a Sound, Video, and Game controller (USB Audio).  I have a board+application that uses the USB-MODEVM drivers to communicate with this host PC and it works flawlessly.
On the 2nd laptop, the drivers fail to install correctly.  Both laptops are identical in hardware/build.
There are two parts of the driver install.  On the laptop that I am having a problem with, the first portion (NI-VISA USB Device) installs correctly, but the 2nd portion, the actual USB Audio portion, does not.  Correspondingly, when I go to Control Panel - Sounds - it does not enumerate in the list of audio devices.  I can verify this by checking, I get a yellow exclamation mark and a code 28 for uninstalled drivers.
As a reference, I've been using the .pdf document titled
TLV320AIC3xEVM-PDK Series Troubleshooting Guide
authored by Jorge Arbona as a guide through this.  I've followed all of the very helpful suggestions in that document, (I'd have been utterly lost without it!) but my system still can't get past the very last install step (in the document referenced above, section 3.2 Device Driver Setup, steps 4-6).  I am guessing I have a conflict somewhere along the way in the install process, but I don't know where to look to try and track it down.
Again, any help would be much appreciated.
USB-MODEVM drivers Windows 7 TLV320AIC3xEVM-PDK Windows XP Windows Vista
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • J Arbona
    Posted by J Arbona
    on Oct 05 2010 14:06 PM
    Verified Answer
    Verified by J Arbona
    Mastermind21620 points
    EEPROM Programmer ~ Original USB-MODEVM 44.1kHz - 16-bits.zip
    Hello Rob,
    The AIC3x and AIC310x EVM-K series currently are not supported under a Windows Vista/7 environment.
    If you would like, you could use the GUI software of another device to communicate to the AIC3x using the command-line interface.
    The AIC3254EVM-U CS http://focus.ti.com/docs/toolsw/folders/print/tlv320aic3254evm-u.html has the EEPROM programming utility. Once installed, go to "Tools > EEPROM Writer" where you can find a tab that explains how to use the DFUTEST.exe program. That software includes v2.03 firmware which is compatible with Windows Vista/7. However, you will not be able to communicate with the AIC3x GUI if you upgrade to v2.03.
    The v2.03 firmware does not use the NI-VISA driver. The device enumerates as a standard HID and USB Audio class devices. The AIC3254EVM-U CS will use the HID interface to communicate register data to the EVM.
    Attached is the firmware image to restore back to the factory USB-MODEVM V0105 used by AIC3x in case you would like to roll back.
    J-
    Report Abuse
    • Reply
  • Liang-Bi Chen
    Posted by Liang-Bi Chen
    on Jul 13 2012 04:10 AM
    Prodigy140 points
    J Arbona wrote the following post at Oct 5, 2010 8:06 PM:
    Hello Rob,
    J-
    Quote
    Dear all,
    I have applied AIC33 EVM now, is also not supported Win7 environment???
    If yes, how to solve this issue?
    Report Abuse
    • Reply
  • J Arbona
    Posted by J Arbona
    on Jul 13 2012 17:21 PM
    Verified Answer
    HI Chen,
    It is now supported in Win7. You can find the driver here: http://www.ti.com/litv/zip/slac521.
    J-
    Report Abuse
    • Reply
  • BHansen
    Posted by BHansen
    on Jul 16 2012 14:08 PM
    Prodigy70 points
    Hi J
    I've downloaded and installed the driver from the slac521.ZIP file several times on my windows 7 system.  The driver appears to load OK when I look in the hardware devices control panel. However, when I launch the application AIC310x and then select the device (AIC3104, on the TLV320AIC3104EVM-K), I get an error dialog saying:
    "Connect USB"  <Retry> <Exit>
    I've tried several USB ports with no luck.
    Is this Win 7 driver known to work?
    Bjarne
    AIC310x TLV320AIC3104EVM Windows7 Win7 USB-MODEVM
    Report Abuse
    • Reply
  • Converter Apps
    Posted by Converter Apps
    on Jul 16 2012 17:27 PM
    Mastermind18965 points
    Make sure you also have the latest version of the GUI which can be downloaded here:
    http://www.ti.com/tool/tlv320aic3104evm-k
    The version on the CD has a bug.
    Report Abuse
    • Reply
  • BHansen
    Posted by BHansen
    on Jul 16 2012 17:31 PM
    Prodigy70 points
    Thanks - yes, I have tried the downloaded GUI application and the downloaded driver.  Still no luck.
    Report Abuse
    • Reply
  • Seth Johnson
    Posted by Seth Johnson
    on Jan 12 2013 14:22 PM
    Prodigy10 points
    Am having the same issues with the newest software. Still need to run the setup in XP compatibility mode or I get an error saying "the windows installer engine is corrupt". The AIC310x.exe application gives just a message box that says "Connect USB" with Retry and Exit. Has this issue been resolved yet?
    Report Abuse
    • Reply
  • SEBA
    Posted by SEBA
    on May 15 2013 06:30 AM
    Prodigy10 points
    I have the same problem with win7 64bit.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
