The datasheet states that the minimum load impedance for the analog outputs is 5kΩ. However the recommended application circuit (see below) has the output impedance on OUTXP as ~1.6kΩ and OUTXN as ~800Ω.
Would you please be able to advise on the best resistor values to use for the application circuit?
Bill
