hi,
i'm trying to configure my aic3206 codec on c5545booster pack for high power high performance output mode, as per the TI example attached below. also added my code. I don't hear any output at all when i run the loopback. I want to run on 8khz sample rate
/* * Copyright (c) 2016, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /*! \file audio_line_in_loopback_test.c * * \brief Functions that configure the audio codec regsiters for the audio * line in loopback operation. * */ #include "audio_line_in_loopback_test.h" #include "audio_common.h" #include "../../../build/boostC5545/audio_line_in_loopback_test/coeff" #include <stdio.h> #include <stdint.h> #include <math.h> extern TEST_STATUS AIC3206_loop_linein(void *testArgs); /** * * \brief This function configures all audio codec registers for * line in loopback test * * \param testArgs [IN] Test arguments * * \return * \n TEST_PASS - Test Passed * \n TEST_FAIL - Test Failed * */ TEST_STATUS AIC3206_loop_linein(void *testArgs) { Int16 sec, msec; Int16 sample; Int16 data1, data2; Int16 output1,output2; /* Configure AIC3206 */ AIC3206_write( 0, 0x00 ); // Select page 0 AIC3206_write( 1, 0x01 ); // Reset codec C55x_delay_msec(1); // Wait 1ms after reset AIC3206_write( 0, 0x01 ); // Select page 1 AIC3206_write( 1, 0x0a ); // Disable crude AVDD generation from DVDD AIC3206_write( 2, 0x00 ); // Enable Analog Blocks, use LDO power AIC3206_write( 123,0x05 ); // Force reference to power up in 40ms C55x_delay_msec(40); // Wait at least 40ms AIC3206_write( 0, 0x00 ); // Select page 0 /* PLL and Clocks config and Power Up */ AIC3206_write( 27, 0x0d ); // BCLK and WCLK are set as o/p; AIC3206(Master) AIC3206_write( 28, 0x00 ); // Data ofset = 0 AIC3206_write( 4, 0x03 ); // PLL setting: PLLCLK <- MCLK, CODEC_CLKIN <-PLL CLK AIC3206_write( 6, 0x07 ); // PLL setting: J=7 AIC3206_write( 7, 0x06 ); // PLL setting: HI_BYTE(D=1680) AIC3206_write( 8, 0x90 ); // PLL setting: LO_BYTE(D=1680) AIC3206_write( 30, 0xb0 ); // For 32 bit clocks per frame in Master mode ONLY // BCLK=DAC_CLK/N =(12288000/8) = 1.536MHz = 32*fs AIC3206_write( 5, 0x91 ); // PLL setting: Power up PLL, P=1 and R=1 C55x_delay_msec(1); // Wait for PLL to come up AIC3206_write( 13, 0x00 ); // Hi_Byte(DOSR) for DOSR = 128 decimal or 0x0080 DAC oversamppling AIC3206_write( 14, 0x80 ); // Lo_Byte(DOSR) for DOSR = 128 decimal or 0x0080 AIC3206_write( 20, 0x80 ); // AOSR for AOSR = 128 decimal or 0x0080 for decimation filters 1 to 6 AIC3206_write( 11, 0x87 ); // Power up NDAC and set NDAC value to 7 AIC3206_write( 12, 0x83 ); // Power up MDAC and set MDAC value to 12 AIC3206_write( 18, 0x87 ); // Power up NADC and set NADC value to 7 AIC3206_write( 19, 0x8C ); // Power up MADC and set MADC value to 12 AIC3206_write( 60, 0x08 ); AIC3206_write( 61, 0x01 ); AIC3206_write( 63, 0xd6 ); /* DAC ROUTING and Power Up */ AIC3206_write( 0, 0x01 ); // Select page 1 AIC3206_write( 12, 0x08 ); // LDAC AFIR routed to HPL AIC3206_write( 13, 0x08 ); // RDAC AFIR routed to HPR AIC3206_write( 0, 0x00 ); // Select page 0 AIC3206_write( 64, 0x02 ); // Left vol=right vol AIC3206_write( 65, 0x20 ); // Left DAC gain to 0dB VOL; Right tracks Left AIC3206_write( 63, 0xd4 ); // Power up left,right data paths and set channel AIC3206_write( 0, 0x01 ); // Select page 1 AIC3206_write( 16, 0x00 ); // Unmute HPL , 0dB gain AIC3206_write( 17, 0x00 ); // Unmute HPR , 0dB gain AIC3206_write( 9 , 0x30 ); // Power up HPL,HPR AIC3206_write( 124, 0x06 ); AIC3206_write( 61, 0x00 ); AIC3206_write( 71, 0x32 ); AIC3206_write( 123, 0x05 ); AIC3206_write( 125, 0x12 ); C55x_delay_msec(1 ); // Wait 1 msec /* ADC ROUTING and Power Up */ AIC3206_write( 0, 0x01 ); // Select page 1 AIC3206_write( 52, 0x40 ); // STEREO 1 Jack // IN2_L to LADC_P through 40 kohm AIC3206_write( 55, 0x40 ); // IN2_R to RADC_P through 40 kohmm AIC3206_write( 54, 0x03 ); // CM_1 (common mode) to LADC_M through 40 kohm AIC3206_write( 57, 0x03 ); // CM_1 (common mode) to RADC_M through 40 kohm //AIC3206_write( 59, 0x00 ); // MIC_PGA_L unmute // AIC3206_write( 60, 0x00 ); // MIC_PGA_R unmute //AIC3206_write( 51, 0x00 ); // SetMICBIAS AIC3206_write( 0, 0x00 ); // Select page 0 AIC3206_write( 81, 0xc0 ); // Powerup Left and Right ADC AIC3206_write( 82, 0x00 ); // Unmute Left and Right ADc AIC3206_write( 83, 0x00 ); // Unmute Left and Right ADC AIC3206_write( 84, 0x00 ); // Unmute Left and Right ADC // AIC3206_write( 86, 0x80 ); // L-AGC configuration // AIC3206_write( 94, 0x80 ); // R-AGC configuration C55x_delay_msec(1 ); // Wait 1 msec /* Initialize I2S */ initialise_i2s_interface(); gpio_interrupt_initiliastion(); /*Circular Buffer FIR Implementation*/ int AUDIO_FRAME_LEN=80000; Int32 OutFrame[8000]; Int32 OutCircBuf[8000]; #define fs 8000 int N=135; int i; int index1=0; int index2=N; Int16 x[2*135]; Int16 z[2*135]; long y1new,y2new; int k=0; I2S_writeLeft(0); I2S_writeRight(0); /*for(n=0;n<N;n++){ coeff1[n]=round(coeff[n]*32); }*/ // Create audio buffer static Int16 buf[80000]; // buffer int n=0; int a=0; // buffer index FILE *pipeout; pipeout=fopen("output.pcm","wb"); //for ( sec = 0 ; sec < 600 ; sec++ ) while(1) { for ( msec = 0 ; msec < 1000 ; msec++ ) { for ( sample = 0 ; sample < 8 ; sample++ ) { // Read 16-bit left channel Data I2S_readLeft(&data1); // Read 16-bit right channel Data I2S_readRight(&data2); // As a new sample is received put it in two places x[index1] = data1; x[index2] = data1; z[index1] = data2; z[index2] = data2; y1new=0; y2new=0; for(i=0;i<N;i++){ y1new = y1new + (long)coeff[i]*x[index2-i]; y2new = y2new + (long)coeff[i]*z[index2-i]; } index1 = (index1+1)%N; index2 = index1+N; output1=y1new>>15; output2=y2new>>15; if(a<AUDIO_FRAME_LEN){ OutFrame[a]=output1; } /*if(n<80000){ buf[n]=output2; n=n+1; }*/ // Write 16-bit left channel Data I2S_writeLeft(data1); // Write 16-bit right channel Data I2S_writeRight(data2); } if(sw3Pressed == TRUE) { /*FILE *pipeout; //pipeout = popen("ffmpeg -y -f s16le -ar 8000 -ac 1 -i - test.wav", "w"); pipeout=fopen("output.pcm","w"); fwrite(buf, 2, 1, pipeout); fclose(pipeout);*/ break; } } if(sw3Pressed == TRUE) { break; } } //fwrite(buf, 2, 80000, pipeout); for (i=0; i<AUDIO_FRAME_LEN; i++) { OutCircBuf[AUDIO_FRAME_LEN+i] = OutFrame[i]; } fclose(pipeout); /* Play Loop for 5 seconds */ /* for ( sec = 0 ; sec < 500 ; sec++ ) { for ( msec = 0 ; msec < 1000 ; msec++ ) { for ( sample = 0 ; sample < 16 ; sample++ ) { Read 16-bit left channel Data I2S_readLeft(&data1); Read 16-bit right channel Data I2S_readRight(&data2); Write 16-bit left channel Data I2S_writeLeft(data1); Write 16-bit right channel Data I2S_writeRight(data2); } if(sw3Pressed == TRUE) { break; } } if(sw3Pressed == TRUE) { break; } }*/ I2S_close(hI2s); // Disble I2S AIC3206_write( 1, 0x01 ); // Reset codec return 0; } /** * * \brief This function used to initialise i2c interface and run * audio line in loopback test * * \param testArgs [IN] Test arguments * * \return * \n TEST_PASS - Test Passed * \n TEST_FAIL - Test Failed * */ static TEST_STATUS run_audio_line_in_loopback_test(void *testArgs) { Int16 retVal; Uint8 c = 0; /* Enable clocks to all peripherals */ CSL_SYSCTRL_REGS->PCGCR1 = 0x0000; CSL_SYSCTRL_REGS->PCGCR2 = 0x0000; retVal = SYS_setEBSR(CSL_EBSR_FIELD_PPMODE, CSL_EBSR_PPMODE_1); // Configure Parallel Port for I2S2 retVal |= SYS_setEBSR(CSL_EBSR_FIELD_SP1MODE, CSL_EBSR_SP1MODE_1); // Serial Port mode 1 (I2S1 and GP[11:10]). retVal = initialise_i2c_interface(testArgs); if(retVal != 0) { C55x_msgWrite("I2C initialisation failed\n\r"); return (TEST_FAIL); } C55x_msgWrite( "Test Receives audio samples from LINE IN and output the same\n\r" "on HEADPHONE port\n\n\r"); C55x_msgWrite("Connect headset to the HEADPHONE port of the BoosterPack\n\n\r"); C55x_msgWrite("Connect a LINE-IN cable between the audio port of the\n\r" "Test PC and LINE IN of the BoosterPack\n\n\r"); C55x_msgWrite("Play any audio file from the Test PC and Check \n\r" "Audio from the headset connected to BoosterPack\n\n\r"); retVal = AIC3206_loop_linein(testArgs); if(retVal != 0) { return (TEST_FAIL); } #ifdef USE_USER_INPUT C55x_msgWrite("Press Y/y if the Audio stream from LINE IN is\n\r" "observed at the headset connected to HEADPHONE port,\n\r" "any other key for failure:\n\r"); C55x_msgRead(&c, 1); if((c != 'y') && (c != 'Y')) { C55x_msgWrite("Audio Loopback from LINE IN to the HEADPHONE port\n\r" "is not proper\n\r"); return (TEST_FAIL); } #endif return (TEST_PASS); } /** * * \brief This function performs audio line in loopback test * * \param testArgs [IN] Test arguments * * \return * \n TEST_PASS - Test Passed * \n TEST_FAIL - Test Failed * */ TEST_STATUS audioLineInLoopbackTest(void *testArgs) { TEST_STATUS testStatus; C55x_msgWrite("\n*******************************************\n\r"); C55x_msgWrite( " AUDIO LINE IN LOOPBACK TEST \n\r"); C55x_msgWrite( "*******************************************\n\r"); testStatus = run_audio_line_in_loopback_test(testArgs); if(testStatus != TEST_PASS) { C55x_msgWrite("\nAudio LINE IN Loopback Test Failed!\n\r"); return (TEST_FAIL); } else { C55x_msgWrite("\nAudio LINE IN Loopback Test Passed!\n\r"); } C55x_msgWrite("\nAudio LINE IN Loopback Test Completed!!\n\r"); return testStatus; }
8322.Playback-Recording(8KHz).cfg
note:- don't follow the comments in my code, they were default comments and i didn't change according to my settings.
