Sir,
I want to prepare circuit where single voltage supply will be using by multiple circuit but one at a time.So is there any Demultiplexer IC which can do this and it should be automated by python code .
Sayali
Hi Sayali,
We have dual channel and quad channel load switches such as the TPS22976 and TPS22993 that may be able to help here. You could tie the inputs together and use the enable control to turn on/off specific channels. Would solutions like these work?
Alek Kaknevicius
Hi Salyali,
What sort of functionality are you looking to program? In general, these are pretty simple devices, but the TPS22993 can be programmed through I2C.
Alek Kaknevicius
