• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » /etc... Data Converters » /etc... Data Converters Forum » use of ads 1247 to interface two pt100 sensors
Share
  • Forum
Options
  • Subscribe via RSS
This question is not answered
varun dongre
Posted by varun dongre
on Jun 18 2012 04:44 AM
Prodigy80 points
hyyy
i am varun. i am developing a temperature controller in which i wanna use ads1247 adc to get a resolution of 0.001C. as i know frm datasheet ads1247 adc can b interfaced with two pt100 sensors...can u suggest some circuit configuration to use two pt100 sensors (in 4 wire configuration) with this ADC.  my main application is to show the temperature of two different positions simultaneously. so is this can be done by a single Ads1247 adc? i am using atmega16l micro controller for this application.i wanna give  1mA current source externally and internal clk sources is in use. plz help ...weting for ur reply
regards
varun
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Luis Chioye
    Posted by Luis Chioye
    on Jun 18 2012 20:21 PM
    Genius17475 points
    Hello Varun,
    Attached below is an application note that you will find helpful.  It describes in detail the ADS1248/7 measuring RTD's in the two-wire; three-wire and four-wire configuration.  The device offers the programmable IDAC current sources that can be used to excite the RTD.
    The ADS1248 and ADS1247 is a single ADC with a multiplexer in the front.   The ADS1248 provides more input channels in the multiplexer and in addition the IEXC1 and IEXC2 current output pins. The user could connect two or three RTD's to the ADS1248 device; and change the multiplexer settings to measure the different RTD's in order to measure one RTD at a time.  If measuring one RTD at a time is acceptable in your configuration , you could use the ADS1248 with up to (3) RTD's as shown on the slide provided.   If you need to measure two different RTD's simultaneously, you will need (2) ADS1247 devices.
    Please find the application note below showing the ADS1248 /7 measuring RTD's and a block diagram showing the 4-wire RTD connections to (3) RTD's using the ADS1248 (measuring one-RTD at a time).
    Thank you and Best Regards,
    Luis
    ADS1247/8 Application Note measuring RTD's:
    http://www.ti.com/lit/an/sbaa180/sbaa180.pdf
    (3)  Four-Wire RTD's connected to the ADS1248 (measuring one RTD at a time)
    7587.ADS1248_4wire-1.pdf
    Report Abuse
    • Reply
  • varun dongre
    on Jun 19 2012 11:43 AM
    Prodigy80 points
    hey!!!!
    thanks for quick and valuable reply. design looks nice but i have a doubt that if this internal current source is stable enough to measure temperature of a far position. cable length is approx 8 m long.wat if i use external current source with opamp amplification hence the input to the ADC is single ended.
    i also want to know the calibration proceess of temperature, i know one method of adjusting the offset voltage and gain of the opamp  as to make the input of the adc temperature equivalent voltage. OR  i have to use RTD equation to in programm of MCU.
    weting  for nw ideas.....
    thanks
    varun
    Report Abuse
    • Reply
  • Luis Chioye
    on Jun 19 2012 23:13 PM
    Genius17475 points
    Hello Varun,
    The ADS1248 provides an internal PGA (programmable gain amplifier) with gains of x1 to up to x128; therefore, you probably will not need an external amplifier.
    The device offers different calibration options detailed on pages 32-33 of the datasheet.  The offset calibration can be performed using the self-offset calibration command (SELFOCAL).  The PGA gain error of the ADS1248 is very small, typically 0.005% (max 0.02%).  Most users do not perform a gain calibration and rely on the factory trimmed gain precision built in the device.
    Regarding the voltage to temperature conversion; some users perform the conversion using the RTD equation; or use a look up table programmed in the MCU.  The slides attached below provide an overview of the different methods to perform the voltage to temperature conversion and the trade offs between the different methods.
    3823.Foruml RTDUsing Delta-Sigma ADC.pdf
    I will go ahead and verify the IDAC current stability.
    Luis
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
