can anyone get me a best document to understand ADC to its depth with all parameters, conversion process etc.
Hi Guru,
What type of ADC are you interested in learning about? Delta-Sigmas and SARs will be the most common ADC types until you get to the high speed applications.
The range of topics and ADC applications is very wide and there are a lot of good reads available.
For basics look up:
Chris
Sir,
can you tell me what are causes of the errors of adcs' like offset, gain error, dnl, inl, how to solve them. You can also suggest appropriate document.
Hi Guru,
Here are some other good resources:
You may need to start looking into design textbooks for more understanding about the source of these errors. Most of the shorter literature will only cover data converter applications. There are more articles on op amp errors - many of the sources of op amp errors are related because they are both analog designs and things like matching and manufacturing tolerances impact performance.
Chris
