hi
i m interfacing DAC7734 with microcontroller(look up table) for three phase sine wave generation my concern is whether I can maintain Phase between three signals?
hi
It all depends on your requirements.
hi Eugenio Mejia
Thank you for the information.
Short answer: Yes you can. With many more points too.
I attached a quick calculation for your own reference.
You can play around with the clock to suit you needs.
I found that for your application the minimum CLK should be 0.25 MHz.
If you wanted to run this at max CLK would you want to update all the channels at the exact same time, of would you want to stagger them? This can change the timing scheme a little and with an 8MHz CLK you can achieve up to 10us writes per channel. (The tool does not show this because you have to do some optimization, if you are interested in this let me know and I can share some more details.)
