We are using the ADS1158 sensor bias facility in order to detect open circuit conditions at the analogue inputs. The datasheet comments:
"Note that the interaction of the multiplexer resistance with the current source may lead to degradation in converter linearity. It is recommended to enable the current source only periodically to check for open inputs and discard the associated data."
Can you provide any empirical data to support this statement with regards both frequency of activation of this mode which would be considered more than 'periodically' and to what extent the linearity could be affected please? Is this an issue with the 1.5uA current source selected as well as the 24uA?
Gary.
