• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » High Speed Data Converters » High Speed Data Converters Forum » DAC5688 Clock Modes
Share
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 6 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 7 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
DAC5688 Clock Modes
DAC5688 Clock Modes
This question is answered
Alex Wong CS
Posted by Alex Wong CS
on Jan 11 2012 04:48 AM
Intellectual340 points
Hi all,
I use DAC5688 in software radio PCB design. It is connected and configured by a Xilinx Virtex 6 FPGA. I have some questions and would like to get some hints.
For the clock modes, we would like to use External mode or PLL mode, such that only one pair of clock input is required. From the datasheet, it is cleared that
In External mode, DAC output sample rate (fdac) is provided to CLK2/C.
In PLL mode, an external reference clock is provided to CLK2/C, and uses the PLL multipler to obtain the high rate fdac.
In datasheet, it is said that "The CLKO_CLK1 pin is configured as an output in this mode and will toggle at a required frequency for the configured interpolation rate and data mode." I know I can configure CLKO_CLK1 to be an output to drive the input data source (FPGA in my design) that sends the data to the DAC. The spec says CLKO max frequency is 160MHz.
However, how can I set CLKO at a particular frequency? I read through the spec it does not find info saying how I can derive CLKO output from the CLK2/C.
I would like to do the following:
(a) In External mode, CLKO fdata would be a divided clock from the CLK2/C fdac.
(b) In PLL mode, CLKO fdata is the same as the external reference clock source.
Thank you for your advice.
Alex
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kang Hsia
    Posted by Kang Hsia
    on Jan 13 2012 08:26 AM
    Verified Answer
    Verified by Kang Hsia
    Genius15360 points
    Hi Alex,
    You are correct that In both the external mode and PLL modes the CLKO will output the required DATACLK frequency for the configured interpolation and data input mode. The CLK1IN_ENA register in config2 will need to be set to "0" in both modes. The DAC5688's internal divider logic will automatically derive the CLKO from DAC's internal clock, so you cannot set CLKO at a other frequencies other than the one needed to latch in the data properly.
    For instance, if the DAC output update rate is at 320MHz with 4x interpolation. The effective data rate is 80MSPS. The DAC will latch in data in SDR fashion.
    1. With normal dual bus mode, the CLKO will toggle at 80MHz to latch in all 32-bits of I/Q data.
    2. With interleaved bus mode, the CLKO will toggle at 160MHz (2x required to interleave) to latch in 16-bit of I/Q interleaved data.
    3. With half-rate bus mode, the CLKO will toggle at 40MHz.
    You can use this CLK0 as a reference to the FPGA and establish the required setup/hold time for the DAC's data input.
    -KH
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
