Texas Instruments
  • Samples Cart - Add Samples Samples & Purchase Cart
  • Contact Us
  • TI Worldwide: United States
  • my.TI Login
  • Products
  • Applications
  • Design Support
  • Sample & Buy
  • All Searches
TI Home » TI E2E Community » Support Forums » Data Converters » High Speed Data Converters » High Speed Data Converters Forum » ads62p29 LVDS output
  • Join
  • Sign In with my.TI Login
TI E2E™ Community
  • Home
  • Support Forums
  • Videos
  • Blogs
  • Groups
  • More ...
  • Go
  • Advanced Search
Share
Details
Rate This
  • 9 Replies
  • 2 Subscribers
  • 451 Views
  • Posted4 months ago
Options
  • Subscribe via RSS
Tags
  • .ini
  • 100Ohm differential
  • 2s complement number
  • 50Ohm Differential
  • 62P43EVM
  • 74AC573
  • A/D converters
  • AC coupled
  • AD62P43EVM
  • ADC
  • ADC arrays
  • ADC data analysis
  • ADC digital output unstable (Any design issue?)
  • ADC jitter
  • ADC SNR
  • ADC undersampling AD921 SDR DSP jitter
  • adc0816
  • ADC12C
  • ADC12D1600RFRB
  • ADC12D1800 Reference Board
  • ADC12D1800RF ML605 gtx transfer fmc
  • ADC12D1800RFRB
  • ADC12D1X00RFRB wave vision 5 ADC 12bit external clock
  • ADC12D500RF
  • ADC12Dxx00
Forum - Title
Welcome to the High Speed Data Converters Section of the TI E2E Support Community. Ask questions, share knowledge, explore ideas, and help solve problems with fellow engineers. To post a question, click on the forum tab then "New Post".
  • Get this RSS feed
  • Home
  • Announcements
  • Forum
  • Files
  • Design Notes
New Post
This question is answered
ting wang93586
Posted by ting wang93586
on Jan 12, 2012 2:19 AM
Prodigy90 points
hello,everyone,
I am trying to do  some evaluation on ads62p29 EVM_rev_C board.
This is what I got from the DDR LVDS interface.RX_OUT_oddl[11:0] is the signals from the ADC's LVDS after the DDR_LVDS logic in the FPGA board.
I don't have the TSW1200, so I evaluate the ADC in my Altera ArriaII board.
All the configuration is default.
CLK of the ADC is a external 150MHz. (use option3. LVCPEL without  245.76MHz filter)
Input signal is a sine wave (Vpp = 1V, frequency = 200KHz, Voffset = V, 50om resistence signal output from a Function waveform generator)
More over, either the sine wave or square wave input ,the output is no different. All these output seems like a square wave(very likely the picture blow)
if I change the signal's input frequency or amplitude , the waveform changes as it should be. (SO the signal has been transmitted to the FPGA)
What's more, I change the SEN from LVDS 2's complement to LVDS binary offset. There is no difference between what I got from FPGA.
Can anyone help me to explain this ?
thank you
Alan
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Matt Guibord
    Posted by Matt Guibord
    on Jan 16, 2012 12:05 PM
    Expert5650 points
    Hi Alan,
    First, I think you need to verify that you are recieving the data correctly from the ADC. The ADS62P29 provides test modes to verify the correct transmission of data. You can use the "TI ADC SPI Interface" software tool to put it in this test mode. One of the most useful patterns is to provide a custom pattern where you set only one bit at a time and verify that that bit is being read and placed correctly. Do this for all bits. Once bit placement has been verified, you can use the toggle pattern and digital ramp to verify correct timing.
    http://www.ti.com/tool/hsadc-spi-utility
    Matt Guibord
    Report Abuse
    • Reply
  • ting wang93586
    on Feb 6, 2012 8:06 PM
    Prodigy90 points
    hi,matt,
    thank you very much for your reply.
    I've tried this spi_gui to verify my EVM. Here is some screen shot from oscilloscope under test pattern.
    pic1 is  LVDS_CLK pair waveform.
    pic2 is data pair waveform under toggle mode.
    pic3 is ramp pair wave form under ramp mode.
    all waveform tested in the configuration: LVDS output ,low speed, 2's complement.
    As you can see . It seems that lvds clk is abnormal.
    Then I tested this under the CMOS output : clk output is as follows.
    The input clk is from a sigal generator and is a 20MHz, 1.5Vpp, sine-wave signal as the user's guide said.
    I am depressed for this strange thing.
    I am very appreciated for your letter.
    thx.
    Alan
    Report Abuse
    • Reply
  • Matt Guibord
    on Feb 6, 2012 8:56 PM
    Expert5650 points
    Alan,
    Have you enabled low-speed mode? Do this by writing 0x04 to register 0x20. This mode should be enabled for clock speeds slower than 80 MSPS.
    Secondly, the DLL in the part is incapable of keeping a 50% duty cycle for such slow clocks. The duty cycle distortion is expected, however setup and hold times should still remain sufficient and should not effect performance.
    Matt Guibord
    Report Abuse
    • Reply
  • ting wang93586
    on Feb 7, 2012 12:53 AM
    Prodigy90 points
    hi,Matt,
    thank you for your quick reply.
    As I mentioned that all waveform tested under the configuration: LVDS output ,low speed, 2's complement which was set by ADC GUI instead of the low-speed register.
    I am confused about the DLL module. Do you mean 20MHz is beyond its lock capability?
    Then I will have a  try with a high speed external clk (>80MHz).
    best regards.
    Alan
    Report Abuse
    • Reply
  • Matt Guibord
    on Feb 7, 2012 8:05 AM
    Expert5650 points
    Alan,
    As you decrease the sampling frequency the timing only gets better and therefore the DLL is no longer needed to guarantee correct timing. Thus we use low speed mode to disable it.
    Matt Guibord
    Report Abuse
    • Reply
  • ting wang93586
    on Feb 11, 2012 9:23 AM
    Prodigy90 points
    Hi,Matt,
    Thank you for your reply.
    I have another question about the CLK input of high speed ADC.
    As I known, high performance sample needs clean and lower jitter CLK input. If the on board crystal is used, the low pass filter and PLL is needed for the VCXO crystal.
    Compared with crystal solution, DDS maybe is another choice for good CLK source.
    I want to use high speed ADC for ADS62P29 external clk. I checked the AD9854 and AD9910(both manufactured by ADI company ) can support high speed sine-wave output, the maximum frequency of AD9854 is 120MHz and later is 400MHz.
    Is that realistic for ADS62P29 EVM's CLK source or is there any risk I have to take into account?
    Alan
    ps:AD9854 specification
    http://www.analog.com/en/rfif-components/direct-digital-synthesis-dds/ad9854/products/product.html
    Report Abuse
    • Reply
  • ting wang93586
    on Feb 14, 2012 11:29 PM
    Prodigy90 points
    Hi,Matt,
    I have got the expected result after a 120MHz clk source is used to drive the ADC.
    But you still have not answer my question about ADC CLK.
    Thank you very much.
    here is my last letter.
    Alan
    Report Abuse
    • Reply
  • Matt Guibord
    on Feb 15, 2012 2:33 PM
    Verified Answer
    Verified by ting wang93586
    Expert5650 points
    Alan,
    I do not think that is a good choice for this. The RMS jitter in clock generation mode is 25 ps. We generally recommend less than 1 ps of jitter. A better choice would be the LMK03806 or LMK04800 using a good quality cyrstal or VCXO. Take a look at these.
    http://www.ti.com/product/lmk03806
    http://www.ti.com/product/lmk04800
    Matt Guibord
    Report Abuse
    • Reply
  • ting wang93586
    on Feb 16, 2012 8:12 AM
    Prodigy90 points
    Matt,
    Thank you for your suggestion.
    I am a freshman in this field.
    Your help is greatly appreciated.
    Alan
    Report Abuse
    • Reply
Share
ALL CONTENT AND MATERIALS ON THIS SITE ARE PROVIDED "AS IS". TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH REGARD TO THESE MATERIALS, INCLUDING BUT NOT LIMITED TO ALL IMPLIED WARRANTIES AND CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHT. TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH RESPECT TO THESE MATERIALS. NO LICENSE, EITHER EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE, IS GRANTED BY TI. USE OF THE INFORMATION ON THIS SITE MAY REQUIRE A LICENSE FROM A THIRD PARTY, OR A LICENSE FROM TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Products | Applications | Design Support | Sample & Buy RSS
TI Worldwide | About TI | Contact Us | Investor Relations | Press Center | Corporate Citizenship | Careers | Tags | my.TI Login | All Searches | Site Map
© Copyright 1995- Texas Instruments Incorporated. All rights reserved. Trademarks | Privacy Policy | Terms of Use
