Clicking on the "Order Online" button on the ADC12D1800 Reference Board webpage simply takes you to a National webpage; clicking on that "Buy Now" button takes you to a Digi-Key web page... that says "Product Not Found"
Is there some secret portal where these are actually for sale?
Regards, Neil P. Albaugh ex-Burr-Brown
Hello..anyone out there?........Hello............hello.....................hello.....................................
hello.........................................................hello.........................................................................hello.......................................................................................................................................
Hi Neil,
I apologize for the difficulties in ordering a Reference Board. We have experienced a few hiccups, as the National website has recently undergone some major components of changing over to the TI website, and this has caused the issue with ordering boards.
Our major distributors are still currently able to sell this boards. You can call the distributor, e.g. Arrow, and provide the part number for the board. The distributor would then validate that the part is real and submit a quote request to determine pricing.
Please try this route - and let me know if you are not able to successfully order a board and I will help get one through.
Kind regards,
Marjorie
Thank you, Marjorie. I already know the price of the evaluation board-- it is $995 according to your web page: http://www.ti.com/tool/adc12d1800rb
The question is who sells it--- the reference to Digi-Key leads nowhere so is Arrow the correct distributor or are there other choices?
Best of luck with the TI takeover......................
$995 is the correct price. The major distributors are Arrow and Avnet. For example, I found the board at Avnet:
http://avnetexpress.avnet.com/store/em/EMController?langId=-1&storeId=500201&catalogId=500201&term=adc12d1800rfrb&searchType=&advAction=&N=0&Ne=100000&action=products
Thank you for the well wishes!
Marjorie,
Sorry to step into this thread, but I am working with Neil on this project, and have a related follow-up.
We are having a dickens of a time ordering this board. If I look up the board via the TI site, and follow the links all the way through to "Purchase," it ends at the DigiKey website with a failure to find the product. If we work with Avnet as you suggest above, the sales folks get in the loop, contact TI, then insist that this is an obsolete product. They have gone so far as to direct us to Rochester Electronics to find older, obsolete TI products. The same result has occurred with a number of online vendors purporting to offer this product.
Could you kindly direct Neil and I through a solid sales resource that can enable us to purchase the evaluation board?
Thank you so much, and best regards,
--Ken
Hi Ken,
Sorry again for the difficulties; I just had a chat with Neil and have at least resolved your order. Your board should arrive to him on Monday.
I am currently working with the TI distribution managers for Avnet, Arrow, and Digikey to make sure that these boards are orderable; I hope to close on the issue by next week. Avnet did not have our board info loaded into their system, which is why the board appeared to be obsolete when you tried to order it. After things are sorted out with the distributors, I will respond again to this post with some links to order boards.
Wow! That is simply fantastic! Thank you so much for stepping in and resolving the situation so amicably and so quickly. I'll keep an eye out for your later postings with links to the distributors.
Again, thank you for going above and beyond; it is greatly appreciated.
You are very welcome! Let me know if you have any further questions, as your development with the product continues.
Marjorie;
The converter board arrived this morning. Many thanks for your sincere efforts on our behalf.
A follow-up, with questions...
The board arrived with WaveVision v 5.0.5.284; this is a non-starter under Windows 7. I did find and download v 5.0.6.465 (the latest?) and was able to communicate with and exercise the board. So far, so good; however...
The intent is to use the board with a custom Windows application. To that end, I was previously provided a zip file including the Programmers Guide to the WV5 DLL. Unfortunately, the source files are based upon the old DLL, which does not use the Win7-compatible USB drivers. I went ahead and used explicit DLL linking to access the new version, but only met with partial success. I can communicate with the DLL, issuing commands to: set the debug output file (WvDebugModuleSetOutputFilename), initialize the module (WvDebugModuleModifyAll), and enumerate the attached board (WvBoardEnum). It was on this last item I hit a snag. The function is returning FALSE, indicating it could not enumerate the board. A check of the debug output shows: "GEN: Exception caught" and "BOARD_STATE: Internal error. user handle not found." I'm guessing that something has changed in either the startup sequence or the function parameters from the older version that I have, but I have no real way to go much further.
Is there a newer zip file with the requisite .h and .lib file to support the new DLL, and if applicable an updated version of the Programmer's Guide?
Any help you can provide to point me in the right direction would be greatly appreciated.
Thanks so much, and best regards,
Dear Marjorie,
sorry for stepping into this thread.
I'm working for a company based in northern Italy active in the field of RF/MW systems. We would like to buy the same eval board of this thread, the ADC12D1800RB and we are experiencing the same problem reported here: no way to order this board from usual components reseller (Digikey, AvNet, Arrow, Farnell).
Is there a chance to solve this issue?
Thank you very much,
Alessio Cacciatori
A little bit more info... In an effort to get moving forward, I installed Windows XP as a virtual machine under Windows 7, then installed the older version of WaveVision 5. You have to hold your tongue just right, but you can get WV5 to see the board and acquire waveforms. However, when I now test my custom Windows C++ application, I get essentially the same error, i.e. "user handle not found," although some of the debug messages are a bit different, reflecting the use of the older DLL.
One other bothersome observation... The help file provided with the WV5 DLL Programmer's Guide indicates that the WvBoardEnum function allocates memory for the board name strings, returning a pointer via the location provided in the second argument. The sample Python code included with the DLL kit, though, preallocates the memory for the board name strings. I've tried it both ways just in case, but with no success; I only point it out as an inconsistency in the documentation versus the sample code.
I am now good and stuck, and eagerly await your input. By the way, I noticed there is another thread open in the forum (sorry, I don't have the link) with a user encountering what seems to be the same difficulty with the same DLL tools, posted in mid-April. Might be able to kill two birds with one stone if we get this figured out.
Thanks again!
Hi Alessio,
No problem - you are welcome to join the discussion!
The board is available from Avnet, but we are still working to make it available on Digikey and Arrow. You will have to request a quote since the price is not published. You can do this by going to the link below and selecting 'Request Quote'. Last week, I e-chatted with an Avnet representative to see if I could order the board and she told me to request a quote. One thing to note: there are two similar products, the ADC12D1800 and the ADC12D1800RF and reference boards for both products are available on Avnet:
ADC12D1800 Reference Board:
http://avnetexpress.avnet.com/store/em/EMController?langId=-1&storeId=500201&catalogId=500201&term=adc12d1800rb&N=0&Ne=100000&action=products
ADC12D1800RF Reference Board:
http://avnetexpress.avnet.com/store/em/EMController?langId=-1&storeId=500201&catalogId=500201&term=adc12d1800rfrb&N=0&Ne=100000&action=products
Let me know if you have further questions - and whether you are able to order the board.
Solved it! It turns out the WV5 DLL has a strong dependency on the 'hardware' folder found in the WV5 program directory. By making a copy of said folder in the root of my custom application, i was able to enumerate the boards without error.
I'll post this in the other thread as well, and hopefully it will solve that individual's difficulty as well.
I'm sure there will be more questions as I go, but for now I'm good.
Thanks again,
Fantastic! I'm glad you were able to solve this problem. From our side, we will help you as much as we can with the product, but most of the folks on the team are skilled in analog hardware and software / firmware issues are not our forte.
