• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » High Speed Data Converters » High Speed Data Converters Forum » FMC ADC Adapter
Share
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 1 day ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
FMC ADC Adapter
FMC ADC Adapter
This question is not answered
Christian Geiser
Posted by Christian Geiser
on May 14 2012 09:56 AM
Prodigy30 points
Hi Folks!
I have a queation about the FMC ADC Adapter Card. I want to connect some High Speed ADC's to an SP605 eval Board from Xilinx. Will the Adaptor work with full functionality on an FMC LPC Connector (the SP605 only has an FMC LPC connector)?
Thank you in advance!
Christian Geiser
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Marjorie Plisch
    Posted by Marjorie Plisch
    on May 14 2012 11:30 AM
    Expert3090 points
    Hi Christian,
    Can you please clarify which specific high-speed ADCs you are interested in?  The answer to your question may be different depending upon the product.
    Marjorie
    Report Abuse
    • Reply
  • Christian Geiser
    on May 15 2012 07:55 AM
    Prodigy30 points
    Hi Marjorie,
    thanks for the fast answer.The ADS58C48EVM or the ADS5282EVM (Or do you have some faster 8 Channel ADC's?) are my favorites right now.
    Thanks ,
    Christian
    Report Abuse
    • Reply
  • Richard Prentice
    Posted by Richard Prentice
    on May 15 2012 16:45 PM
    Genius14195 points
    The FMC adapter cards simply pass the LVDS clock and data pairs from the TI High Speed Data Converter EVM through to the FMC conenctor that Xilinx uses into their development platform.   Either of those EVMs you mention should work well into the ML605 development platform.
    One note about the use of the ADS5282 EVM, though.  The DDR bit clock from the ADC EVM is routed to a global clock input, but the frame clock is not.  Early revisions of the FMC adapter card had the frame clock routed to a clock input that could not be used as a data input.  Which of the two routings you want would depend on how you plan to use the frame clock in your design.  What *we* do with the frame clock is we use it as if it were just another data channel that happens to have a known data pattern so that we can key off that pattern and know where the msb and lsb are onthe other 8 data channels.  In fact, frame clock even has the same setup and hold timing specs around the DDR bit clock as the other data pairs, and so we latch it into the FPGA using the bit clock.  Thus we want the frame clock routed to a data pair, not a global clock input despite the presence of the word 'clock' in the name of the frame clock.
    The ADS58C48 is a four channel device, and because the data format is parallel LVDS instead of serial, it uses a lot more pins on the connector, but the FMC adapter board routes them all over to the development platform.
    Richard P.
    Report Abuse
    • Reply
  • Christian Geiser
    on May 20 2012 15:36 PM
    Prodigy30 points
    Thanks for your  detailed Answers Richard, but will it also work well on an SP606 Board? The ML605 has two FMC Connectors (HPC and LPC), but the SP605 only has one FMC LPC connector.
    I read at http://www.xilinx.com/support/documentation/white_papers/wp315.pdf page 3
    "The HPC and LPC connectors use the same mechanical connector. The only difference
    is which signals are actually populated. Thus, cards with LPC connectors can be
    plugged into HPC sites, and if properly designed, HPC cards can offer a subset of
    functionality when plugged into an LPC site."
    So Im a bit affraid of the functionality of the card at my Board.
    Christian
    Report Abuse
    • Reply
  • Richard Prentice
    on May 26 2012 12:59 PM
    Genius14195 points
    I do see now that you did mention the SP605 rather than the ML605 development platform in your first post.   I do not know what potential differences there may be between the Xilinx development platforms for Virtex vs. Spartan.  We do not have one of each development platform in hand for each family of device from each FPGA vendor.  This would be a question for the FPGA vendor directly, I believe.  A Xilinx representative actually picked the pin assignments of the FMC adapter card when we made the board, but with the ML605 in mind.
    If you do have the SP605 in hand already, then you should have or should be able to get the mapping from the FMC connector to the FPGA itself.  The physical design database (schematics) are available on the TI web for the TI EVMs and for the adapter board itself, so you can follow the signal assignments through the connectors to the FPGA.  You would have to do this anyway before you could generate the constraint file for your development code.  You'd mostly want to verify that the LVDS bit clock goes to a suitable clock input to the FPGA, and that all of the data bit LVDS pairs go to LVDS inputs of the FPGA.   I have been told that the LVDS bit clock may not go to a global clock input of the Spartan, but I cannot verify that, and a global clock input may not be necessary if the clock input can still be used in a clock region that encompasses the LVDS inputs.  There are hierarchies of clock inputs and clock buffers, I believe, such as global clock buffers and regional clock buffers, and the Xilinx design tools would tell you if the pin assignment that you end up with into the SP605 would work our not.
    Richard P.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
