• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » High Speed Data Converters » High Speed Data Converters Forum » interfacing differential amplifiers connected in parallel with a high speed ADC as in parallel ADCs
Share
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 22 hours ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 6 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is answered
ibrahim adama
Posted by ibrahim adama
on Jun 04 2012 09:45 AM
Prodigy50 points
hi,
please hope you wouldnt mind if i ask a stupid question? i have problem interfacing differential amplifiers with high speed ADCs i actually want to design a parallel analog to digital converter for high speed sampling, i hope i will get some help from you guys. hopefully waiting for your response.
thank you
ibrahim
ADC12D1800 Reference Board
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Matt Guibord
    Posted by Matt Guibord
    on Jun 04 2012 09:49 AM
    Expert8985 points
    Hi Ibrahim,
    What is the problem you're having? Are you trying to put multiple ADCs in parallel?
    Edit: I noticed that you've tagged the ADC12D1800. Are you trying to use it in interleaved mode or dual mode? What amplifier are you looking to use? Can you provide information about your system?
    Matt Guibord
    Report Abuse
    • Reply
  • ibrahim adama
    on Jun 04 2012 10:49 AM
    Prodigy50 points
    hi,
    thank you for the reply,  actually i am trying to use the ADC12D1800 in interleaved mode, the amplifiers i will want to use is the LMH6552, several amplifiers are to be connected in parallel with the ADC as in a parallel ADC. i am trying to design a time interleaving system for high speed sampling.
    my regards
    ibrahim
    Report Abuse
    • Reply
  • ibrahim adama
    on Jun 13 2012 08:11 AM
    Prodigy50 points
    hi matt
    thank you for the reply,  actually i am trying to use the ADC12D1800 in interleaved mode, the amplifiers i will want to use is the LMH6552, several amplifiers are to be connected in parallel with the ADC as in a parallel ADC. i am trying to design a time interleaving system for high speed sampling.  still waiting for your reply.
    my regards
    ibrahim
    Report Abuse
    • Reply
  • Matt Guibord
    on Jun 13 2012 13:05 PM
    Expert8985 points
    Ibrahim,
    I'm still not sure what your question is. You mention "time interleaving", so will each amplifier drive the input to a mux with the ADC connected to the output? See the block diagram below.
    Matt Guibord
    Report Abuse
    • Reply
  • ibrahim adama
    on Jun 13 2012 22:53 PM
    Prodigy50 points
    thank you matt,
    this is exactly what i am looking for  i will need more enlightenment on this as regards this time interleaving system. because my topic says design of a parallel analogue to digital converter for high speed sampling and timing error correction. please i will need clue how my circuit design should look like?
    i do really appreciate your effort
    regards
    ibrahim
    Report Abuse
    • Reply
  • Matt Guibord
    on Jun 17 2012 20:18 PM
    Verified Answer
    Verified by Matt Guibord
    Expert8985 points
    Ibrahim,
    I am not at all familiar with the design of a time interleaving system. Have you selected a mux yet? How fast does it need to switch?
    Likely you would drive the mux directly with the amplifier and perhaps use a filter after the MUX.
    Matt Guibord
    Report Abuse
    • Reply
  • ibrahim adama
    on Jun 29 2012 21:33 PM
    Prodigy50 points
    matt,
    thank you i appreciate your effort. i am still trying to create a design from the concept you helped me with
    Report Abuse
    • Reply
  • Matt Guibord
    on Jul 09 2012 11:26 AM
    Expert8985 points
    Ibrahim,
    One last note. From a design/cost/size perspective, it is probably best to use a single amplifier after the MUX. Your sources will then directly drive the mux, or you could use a simple buffer before the mux if needed then the diff amp after. The interface between the amp and ADC should be simpler this way. Since there could be large changes in input voltage when the mux switches, you'll need good slew rate and settling times for the amplifier.
    Matt Guibord
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
