• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » High Speed Data Converters » High Speed Data Converters Forum » TSW1400 Download Failure
Share
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 1 day ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 8 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question is not answered
Karl Herb
Posted by Karl Herb
on Aug 03 2012 12:12 PM
Prodigy30 points
Hello:
   I have a TSW1400EVM that I am using to evaluate the ADS6148EVM.  When I attempt to download firmware I receive the following warning.
   Text reads: "Download Firmware JTAG_CHAIN_BROKEN_ERROR The JTAG chain was broken while loading firmware".
How do I fix this? Thanks!
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Jim Seton
    Posted by Jim Seton
    on Aug 03 2012 13:32 PM
    Prodigy700 points
    Karl,
    We are seeing this problem from a few customers and it appears to be related to the pc. Can you send me the type of pc and the operating system you are using. Have you tried a different pc? We are currently trying to resolve this issue and any information you can provide will help us.
    Jim
    Report Abuse
    • Reply
  • Karl Herb
    Posted by Karl Herb
    on Aug 03 2012 13:38 PM
    Prodigy30 points
    It is a Dell tower T3400, the OS is Windows XP Professional SP3. I can try a different computer, I have a T3500 with Windows 7 as well and can try it.
    Karl
    Report Abuse
    • Reply
  • Karl Herb
    Posted by Karl Herb
    on Aug 03 2012 13:57 PM
    Prodigy30 points
    Windows 7 also did not work.
    Report Abuse
    • Reply
  • Richard Prentice
    Posted by Richard Prentice
    on Aug 03 2012 16:05 PM
    Genius14195 points
    We are looking into this, but there are a couple of easy things to ask first, just in case it is one of these things.
    Is the power to the TSW1400 on?  There is a slide switch next to the 6V power input jack.  The first time I installed the TSW1400 I did not think to look at the power switch because the USB port is powered off the USB cable and so the board looks to be 'live' to the GUI even if the FPGA is off.  But the cooling fan on the FPGA was not running, which was my only visual cue that the power was off.  And having the power off to the FPGA gives the same firmware download error.
    Is the USB port being used a USB 2.0 port?  I don't think we support USB 3.0 ports yet, and I'm not sure about USB 1.0 ports.
    Richard P.
    Report Abuse
    • Reply
  • Jim Seton
    Posted by Jim Seton
    on Aug 07 2012 09:31 AM
    Prodigy700 points
    Karl,
    If you are still having troubles with this board, please provide me with your shipping address and we will send you a new board.
    Jim
    Report Abuse
    • Reply
  • Kyle Jero
    Posted by Kyle Jero
    on Nov 19 2012 11:50 AM
    Prodigy150 points
    I am having the same problem Karl reported but I am trying to connect to a ADS4149 board.  Do you have any suggestions?
    Cheers,
    Kyle
    Report Abuse
    • Reply
  • Jim Seton
    Posted by Jim Seton
    on Nov 19 2012 19:45 PM
    Prodigy700 points
    Kyle,
    Can you provide more info on what your problem is?
    1. Does your TSW1400 work with other evm's?
    2. Can you connect to the board with the GUI?
    3. What version of GUI are you using?
    4. What OS are you using?
    5. Is the 5V led on after turning on the main power switch?
    6. If you get to the point where you start loading firmware and it fails, what error message does the GUI report?
    7.Have you tried a different computer? If so, did it have a different OS?
    Jim
    Report Abuse
    • Reply
  • Kyle Jero
    Posted by Kyle Jero
    on Nov 20 2012 07:29 AM
    Prodigy150 points
    Hey Jim,
    Thanks for the quick reply.
    Jim Seton
    Kyle,
    This is the first and only evm we have tried.
    The board is recognized by the GUI, the problem comes when I try to select the ADS from the dropdown, I always get a broken jtag error
    The GUI is version 1.5
    64 bit Windows 7
    Yes
    I'm getting the same 'Download Firmware JTAG_CHAIN_BROKEN_ERROR The JTAG chain was broken while loading firmware' Karl was.
    I have not tried with a different computer.
    Jim
    Report Abuse
    • Reply
  • Jim Seton
    Posted by Jim Seton
    on Nov 20 2012 08:46 AM
    Prodigy700 points
    Kyle,
    If you want to attempt to trouble shoot the board, on the top side of the board near one of the corners of the FPGA are 8 resistors that could possibly cause this problem. Make sure R61, R62, R63, R64, R149, R150, R151, and R152 are all installed and read 0 Ohms across each one. If you want to send the board back for a replacement, please send your board to the following address:
    Jim Seton
    Texas Instruments
    12500 TI BLVD
    Dallas, TX 75243
    M/S 8755
    FedEx account #106695628
    Report Abuse
    • Reply
  • Kyle Jero
    Posted by Kyle Jero
    on Nov 20 2012 09:44 AM
    Prodigy150 points
    They all check out at ~.2 Ohms.
    Report Abuse
    • Reply
  • Jim Seton
    Posted by Jim Seton
    on Nov 21 2012 08:01 AM
    Prodigy700 points
    Kyle,
    Send the board back and we will get another one to you ASAP.
    Jim
    Report Abuse
    • Reply
  • Debbie Sewell
    Posted by Debbie Sewell
    on Nov 26 2012 14:03 PM
    Prodigy20 points
    Hi Jim,
    I am the purchasing representative for UW Madison who purchased this eval board.  Is the FedEx account number the RMA number so that we can return this board for replacement? If not, could you please provide an RMA number for shipment and replacement of this part?
    Report Abuse
    • Reply
  • Jim Seton
    Posted by Jim Seton
    on Nov 26 2012 17:39 PM
    Prodigy700 points
    Debbie,
    This number should allow Fed Ex to bill TI for the shipment. I do not know what a RMA number is.
    Jim
    Report Abuse
    • Reply
  • Debbie Sewell
    on Nov 27 2012 10:01 AM
    Prodigy20 points
    Hi Jim,
    Kyle Jero who has the part for return tried to call FedEx using your account number and they indicated that without a printed label they are unable to help us return this part.
    I believe that you will have to contact FedEx and explain the situation as it is your account number.  Then I think they issue you an RMA (return merchandise authorization) number and send (probably email) a label which you can forward to us to return the part.
    Please let me know what you are able to find out from them.  We are unable to return this part without a label currently.
    Thank you,
    Debbie Sewell
    Report Abuse
    • Reply
  • Jim Seton
    Posted by Jim Seton
    on Nov 27 2012 10:58 AM
    Prodigy700 points
    Debbie,
    You can call TI product support center at 512-434-1560 to get an RMA number for return merchandise. Let me know if this helps.
    Jim
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
