• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » High Speed Data Converters » High Speed Data Converters Forum » ADC12D1600's input power
Share
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 4 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 5 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 11 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
lei gong
Posted by lei gong
on Aug 19 2012 20:52 PM
Intellectual590 points
From the datasheet of ADC12D1600 ,I found in page 15 that "Vin+/- power : 15.3dBm (maintaining common mode voltage, a.c.-coupled)17.1 dBm (not maintaining common mode voltage, a.c.-coupled)" . In the condition that the ADC12D1600 can work normaly, how much the minimal input power?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Avi Chami1
    Posted by Avi Chami1
    on Aug 20 2012 01:31 AM
    Verified Answer
    Verified by lei gong
    Mastermind7385 points
    The minimal power will be the one that will produce at least a change on the LSB. Usually you will plan your system in a way to be sure that you work to full scale range, to use all the bits of your ADC. If the input voltage is very low, you "waste" resolution of the ADC.
    Report Abuse
    • Reply
  • Marjorie Plisch
    Posted by Marjorie Plisch
    on Aug 20 2012 14:53 PM
    Verified Answer
    Verified by Jim Brinkhurst84999
    Expert3070 points
    Hi Lei,
    What you found on p15 is the operating limits for the analog input.  These limits are for what maximum amount of power may be applied to the analog inputs without causing damage to the ADC.  However, 15.3dBm is significantly greater than 0dBFS.
    In order to work "normally", as you mentioned, the analog input signal should be in the range of larger than the noise floor to less than the full-scale range.  Let's tackle the full-scale range first (FSR).  The nominal FSR of these parts is 800mVpp, as may be found in the datasheet Electrical Table.  The FSR can also be adjusted {600mVpp, 1000mVpp}.  Any analog input which the ADC converts which is greater than the FSR will be converted as all 1's at the digital output.
    Regarding the lower limit, Albert is on the right track - Alberts, thanks for your input here.  For an ADC which performance is limited by quantization noise, the minimum power should be that for one LSB.  However, these ADCs are limited by other noise sources, i.e. thermal noise.  For example the noise spectral density for the ADC12D1600 is -151.6dBFS/Hz for the DES Mode.  This implies an SNR of 56.5dB,  so the minimum signal should be greater than or equal to -56.5dBFS.
    Kind regards,
    Marjorie
    Report Abuse
    • Reply
  • lei gong
    Posted by lei gong
    on Aug 23 2012 20:17 PM
    Hi Marjorie,
          Thanks for your reply .
          From the datasheet of ADC12D1600/1000RF, the chip has some kinds of signals of GND,for example GND、GND_TC、GND_DR、GND_E. But from the ADC12D1X00 Reference Board, i found these kinds of signals of GND were connected together. Do like that, cann't it result noise coupling between the analog and digital circuit  in a single ground plate design. If i connect these kinds of signals of GND through beads,will it decrease noise coupling? Which method is better?
    Kind regards,
    Lei
    Report Abuse
    • Reply
  • Marjorie Plisch
    on Aug 24 2012 16:03 PM
    Verified Answer
    Expert3070 points
    Hi Lei,
    The various GNDs are separate on the IC, but it is recommended to use one GND plane on the PCB to connect them.  For RF frequencies, there is less of a benefit to separating the GND planes.  Our Reference Board employs this design and shows very good performance, so that is one example.
    For details on GND and PWR plane recommendations, see the datasheet: Section 18.5 Supply/Grounding, Layout and Thermal Recommendations.  Let us know if you have further questions.
    Kind regards,
    Marjorie
    Report Abuse
    • Reply
  • lei gong
    Posted by lei gong
    on Aug 24 2012 20:03 PM
    Hi Marjorie,
     I am very grateful  for your help ! Thanks again!
    Kind regards,
    Lei
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
