I need your help about some other questions.
1.when the ADC operating in DES mode,how shoud i do to the unused analog input channel DI or DQ?
In datasheet ,the unused channel shoud be connect to ac-ground or VCMO.Because i may use either DES or no-DES mode, if change between the two modes, i have to do hardware change according datasheet.
i am not sure i get the correct understanding. Please give me some guidance.
2.Do I need the DCLK reset by using the DCLK_RST pins when i only use one ADC?
Thank you very much!
looing forward your replys.
