I'm curious what to consider regarding SYSREF once initial alignment is complete and you've entered normal mode. One article indicated:
• Once alignment is completed, future SYSREF pulses may be used to check the alignment of the local frame and multiframe clocks.
• Since a periodic SYSREF signal acts as a sub-harmonic clock of the converter sampling clock and may have spurious effect on the converter performance, it may be turned off during normal operation once synchronization has been achieved.
• If SYSREF is turned off during normal operation, TX and RX devices must have the ability to generate a “Generate SYSREF” request to the clock generator whenever a synchronization request is detected at the SYNC interface.
Is it prudent to turn on SYSREF occasionally? How often? What factors affect this?
All I can think of is that temperature changes may affect timing so it would be smart to check alignment as often as your system architecture allows. Otherwise you would have to rely on frame alignment monitoring (via replacement characters) which doesn't seem like it is deterministic.
