I think the Subject line asks the question succinctly... I want to use multiple lower cost ~100Msps ADCs sequenced properly to achieve an overall sampling rate of 800Msps or greater. Another possibility is using a multichannel ADC where each ADC block could be clocked separately with offset clocks to sequence each ADC block. All the multichannel ADCs I've looked at so far run the ADC blocks off the same clock, so that would not work. Any suggestions would be most appreciated...
-mark
