Other Parts Discussed in Thread: LMK04828, ADC32RF45
Using the latest ADC32RFxx EVM GUI, I am able to program the LMK04828 clocks successfully (verified by scope and lock LEDs), I am able to program the ADC configuration and DDC configuration pages of the ADC32RF45, but I am unable to program the JESD204B configuration page. I have tried using the GUI to set up the ADC32RF45, and I've also tried the configuration scripts from SBAA226. When I attempt to change settings on the JESD204B configuration page, the settings to not take effect - checkboxes will immediately clear, and the multiframe settings box reverts to 0. From reading around on the forums, this seems like it could be a problem with clocks or sysref. I've attached my LMK04828 settings.dini_lmk04828_614p4in_2457p6m.cfg
If I instead use the Quick Setup page in the EVM GUI, I am able to change settings on the JESD204B page, but it destroys my clock settings in the process. If I go back and change clock settings, then I am unable to change settings on the JESD204B page. What settings file is being run with the Quick Setup 'Program EVM' button? I've tried running the scripts from Texas Instruments\ADC32RFxx EVM GUI\Configuration Files\ADC32RF45\DDC Mode\ADC32RF45_DDC_8xIQ_8821.cfg after running my clock settings, but that doesn't seem to change the behavior.
Any suggestions about what to look at would be much appreciated. Thank you!
-Brian
