Hello E2E,
Any guidance on specing a transformer for this? I'm driving a single ended 75 Ohm load.
Let me know what additional information you may need.
Russell
Hello E2E,
Russell
Russell,
Per the data sheet, the best distortion performance is typically achieved with the maximum full-scale output signal limited to approximately 0.5V. This is the case for a 50 Ohm doubly-terminated load (25 Ohms per leg) and a 20mA full-scale output current. So with a 75 Ohm load, to achieve this, you will need to connect a 37.5 Ohm resistor on each DAC output leg of the DAC to ground and select a 1:1 ratio transformer that meets the frequency requirement of your system.
Jim
Russell,
I have never used one of these pulse transformers. I would suggest you have the customer order an EVM and attempt to replace the on-board transformer with this one and give it a try. If they need help with doing this modification, let us know, as we have technicians that may be able to do this for them.
Jim
