Hi
I want to interface LDC1000 with beaglebone black. I can do it by UART but I want to use USB instead.
I tried to find LDC1000 driver, but couldn't find it. Is it available or not for linux?
Mitul Vekariya
Hi
Mitul Vekariya
Hi Mitul,
When you connect through USB it should show up as a serial port. After you plug in do
dmesg | grep tty
you can also try listing the device in /dev/tty
When you open the port (use any baudrate, it is virtual), type '?' for the ASCII-based menu for quick testing. To grab data you will have to either use the legacy protocol in the E2E FAQ documentation or the binary-based protocol. Of course you can use the ASCII too if the limited function suffices.
Hi
Thank you for your answer. You mentioned legacy protocol in E2E FAQ. I couldn't find it. Will you point it out?
Mitul Vekariya
http://e2e.ti.com/support/data_converters/inductive-sensing/f/938/t/295036.aspx#Q18
