• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » TLV5630 Voltage Scale
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 4 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 12 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 24 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is answered
Samuel Hishmeh
Posted by Samuel Hishmeh
on Aug 31 2011 10:28 AM
Prodigy10 points
I am having a problem with the TLV5630 DAC. It's a 12 bit DAC, set to a reference voltage of 5V, Avdd = 5V, Dvdd=3.3, Agnd=Dgnd. The output of the DAC is not scaling with the input, i.e. 1V in does not equal 1V out. The device input range I'm seeing is from 0 to 0xaf2, which should be about 3.4V (0xaf2 * 5V)/0xfff, but it is maxed out at the reference voltage at this point. I don't understand why this might be. I've looked the manual over several times and I don't see any reason why this should happen. Please, can someone help me?
TLV5630 DAC
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Rafael Ordonez
    Posted by Rafael Ordonez
    on Sep 19 2011 18:00 PM
    Verified Answer
    Verified by Tom Hendrick
    Expert5635 points
    Hello Samuel
    It seems you are saturating the reference input. In page 3 of the datasheet, there is a note below the recommended operating conditions regarding the reference input voltage. It mentions that the reference voltage should be less than AVDD/2 to avoid saturation.
    I assume that you want the DAC output to go from 0V to 5V. In this case, you only need a 2.5V reference voltage because the DAC output has a gain of 2.
    Vout_max =  2 * Ref * 0xFFF / 0x1000 = 2 * 2.5V * 4095/4096 ≈ 5.0V
    Vout_min = 2* Ref * 0x000/0x1000 = 2* 2.5V * 0 / 4096  ≈ 0.0V
    Let us know if this solves the issue you see or if you have any more questions.
    Applications Team
    Report Abuse
    • Reply
  • Ali ��nder Biliro��lu
    Posted by Ali ��nder Biliro��lu
    on Aug 03 2012 16:41 PM
    Prodigy50 points
    I have similar problem with TLV5630. I have read the note about the reference voltage that you mentioned.
    My circuit parameters are:
    DVDD=3.3V
    AVDD=3.3V
    Vref=3.0 V (using REF5030 for precision)
    DVDD and AVDD is shorted or not via "0 ohm" resistor, i got the similar result.
    The problem is; when i wrote the input code 0x7FF, I should get the 3V output according to the formula (Vout =  2 * 3.0V * 0x7FF / 0x1000=3V). But, I got 2.1V at the output with 0x7FF code. I tried with other different input codes, i got the similar result. The output voltage is lower than i suspect. The output voltage is changing linearly with the input code, but not correct. I checked the multimeter by measuring the reference voltage and supply voltages. It shows correct values with those measurements.
    Am I missing something? What should be the reason of this behaviour?
    P.S. : TLV5630 is connected to TMS320F28335 in my design. When i enabled the Dout option of TLV5630 by CTRL0 register, I read the correct codes after 16 SCLK cycle. As I thought, it shows that TLV5630 gets the correct input code for conversion.
    Ali Onder Biliroglu
    Report Abuse
    • Reply
  • Rafael Ordonez
    on Aug 03 2012 18:43 PM
    Expert5635 points
    Hi Ali,
    Similar to the previous post, the internal buffer is saturated because Vref(3V) is bigger than AVDD/2 (1.65V).
    The image illustrates what is happening:
    Rafael
    Applications Team
    Report Abuse
    • Reply
    on Aug 04 2012 12:02 PM
    Prodigy50 points
    Hi Rafael,
    First of all, thank you for your reply to my question. I checked the datasheet and the note at page3 again. It is written that "Reference input voltages greater than AVDD/2 causes saturation for large DAC codes.". When i read this note, i thought, I can use the DAC with my external reference(3.0V) linearly, until the output voltage reaches the AVDD value. After then, incresing the input code doesn't change the output voltage. This is what i understood with this explanation exactly with "large DAC codes" words.
    However, I tested the DAC output according to your explanations. And, i changed the formula like
    Vout = 2*2.1*InputCode/4096
    And, the tests show me that it works fine with this formula. At this point, I want to ask, the saturation is stable during the operation or it changes with temperature or sth else? If it is stable, I can use the DAC with this saturated value.
    I'm asking this question, because, I'm using the AVDD voltage as 3.3V. I have two more reference options internally like 1.024V and 2.048V. According to your explanation, 2.048 V > AVDD/2 and it causes the saturation also. If I want to use the DAC without saturation, I should use 1.024V internal reference, but now, I cannot reach the output voltage bigger than 2.048V. But i need 0-3V range with TLV5630.
    The stabilization is important in my application, because, the outputs of the TLV5630, sets the limitation values (for some measured values) in comparator circuits. We are using the comparation outputs in hardware protection and because of the correct protection, the comparation values should be stable. We also have the HW limit setting option with resistor networks, but, we would like to change the comparation value with software if necessary. This is why we are using TLV5630.
    Ali Onder Biliroglu
    Report Abuse
    • Reply
  • Rafael Ordonez
    on Aug 06 2012 14:50 PM
    Verified Answer
    Expert5635 points
    Hi Ali,
    As you suspect, that formula isn’t completely right because the 2.1V cannot be assumed constant for all devices and over temperature. The reason is that any saturated op-amp changes voltage over temp and from part to part.
    Thus, I don’t recommend using a 3V reference that saturates the internal buffer op-amp to 2.1V, or a 2.048V reference because it is too close to the saturation value.
    From the AVDD/2 statement and minimum AVDD voltage (2.7V), it can be estimated more accurately that the reference voltage will not saturate as long as Vref ≤ AVDD-1.35V. In this case, with a 3.3V AVDD, Vref should be less than 1.95V to avoid saturation effects.
    I think a good solution is to use the REF3318 (1.8V) to allow 0-3V DAC output. Besides, it is smaller and lower power than the REF5030.
    As another option, it is possible to use low drift precision resistors to divide down the REF5030 voltage to a value between 1.5V and 1.95V.
    Rafael
    Applications Team
    Report Abuse
    • Reply
    on Aug 08 2012 15:42 PM
    Prodigy50 points
    Hi Rafael,
    First of all, I'm sorry for the late reply and also thanks for your great support.
    Actually, I have already done the PCB and I used REF5030 with SOIC8 package. So, it is not possible to integrate the REF3318 sith SOT-23 package. But, maybe I can try the voltage divider solution with some modifications on PCB. What else, thanks for all information. At least, I can do the necessary modification at 2nd revision of the PCB. Maybe, I can try the 2.048V internal reference at this revision.
    I wonder, why TI doesn't have series voltage reference IC with 1.5V output voltage. I wonder, because, C2000 series are most popular motor control DSPs on this platform. And as you know, their ADC input voltages are limited between 0-3V. When we want to read the AC current and voltages from motor setup, we are scaling the measurements and adding the 1.5V offset to match the ADC inputs. At this point, for precision, we need precision voltage reference IC with 1.5V output.
    By the way, thanks again for all the information.
    Ali Onder Biliroglu.
    Report Abuse
    • Reply
  • Tom Hendrick
    Posted by Tom Hendrick
    on Aug 14 2012 18:46 PM
    Guru86190 points
    Hi Ali,
    Thank you for the feedback.  There are several voltage reference ranges we'd like to include in our portfolio and we'll work with the C2000 team to get something optimized for the internal ADC of that controller series.  Your 1.5V suggestion is a good one and we'll take a look at it - stay tuned!
    Tom
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
