• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS1282 SPI interface Problems.
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 2 days ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 8 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 16 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
  • Chris Snell
    Posted by Chris Snell
    on Feb 22 2012 08:40 AM
    Prodigy30 points
    I've got a similar problem, where I can't recover from a SPI bus lock up.
    I have a similar set up where the SPI bus is multiplexed to 3x ADS1282 via a CPLD.
    If the microcontroller driving the SPI bus resets, the ADS1282 locks up and stops toggling the DRDY pin.
    I have a hard pull-up on the ADS1282 RESET pin so am unable to toggle it without a hardware change.
    When the ADS1282 locks up I can only get it to work again by cycling power to the board.
    The data sheet suggests that I should be able to recover from a lock up by holding the SCLK low for 64 DRDY cycles.
    I've tried holding the SCLK low for >300ms and and have checked that this period is clean and there are no glitches.
    I then send a reset command, and try to read from the device, the device remains unresponsive, no DRDY and no data.
    Is this a known issue?  Do I need to modify my hardware so that I can toggle the RESET pin, or is  there something else I can do to recover from the lock up?
    Chris
    ADS1282
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Tom Hendrick
    Posted by Tom Hendrick
    on Feb 22 2012 15:49 PM
    Guru86375 points
    Hi Chris,
    Welcome to the e2e forum!  I'm sorry to hear that you are also experiencing SPI lockout issues with the ADS1282.  Can you please send along some screen shots of your communications interface (the SCLK, SDI, SDO, etc)?  Do you have any idea why your micro might reset?  If there is some sort of voltage brownout/droop that causes your CPU to reset, that might also cause problems with the ADS1282 and may explain why the SCLK reset is not working.  Using the HW reset pin may help, but it might not get to the root cause of your issue.
    Tom
    Report Abuse
    • Reply
  • Chris Snell
    on Feb 23 2012 11:12 AM
    Prodigy30 points
    Hi Tom,
    We are deliberately resetting the microcontroller as part of our fault recovery testing.  The power supplies to the ADCs are stable throughout the reset.  The reset could occur at any time, including during an SPI transfer.  It is also probably that the CLK input is unstable and interrupted during the reset.
    When the microcontroller boots up, it holds the SCLK line low for 300ms in order to reset the SPI bus.  It then sends a SDATAC and a RESET command via the SPI bus.  The configuration registers are updated.  When reading from the device, all registers read as zero. A RDATAC command is sent, but we do not get a DRDY signal.
    I have modified one of our boards to allow the reset pin to be toggled; this does solve the problem, but is a very difficult and expensive solution as we have chosen to tie the reset pin high in our board layout.
    I had assumed that once the SPI bus was freed, sending a RESET command would have the same effect as toggling the reset pin.  Is this not the case?
    The same code is used during a cold reset and the ADCs function properly.
    I hope this gives you the information need to help debug the lock up issue.
    Chris
    Report Abuse
    • Reply
  • Tom Hendrick
    on Feb 28 2012 15:16 PM
    Guru86375 points
    Hi Chris,
    There is nothing that I am aware of that would cause this to happen - sending the reset command should clear/reset the part.  Are you toggling the /CS line as well?  Can you send screen captures that might help us try to reproduce your setup??
    Tom
    Report Abuse
    • Reply
  • Chris Snell
    on Feb 29 2012 06:01 AM
    Prodigy30 points
    The ADS 1282 does not have a /CS pin.
    Either holding SCK low does not fully reset the SPI bus, or, sending the RESET command does not reset the part in the same way as toggling the reset pin.
    Report Abuse
    • Reply
  • Tom Hendrick
    on Mar 03 2012 14:06 PM
    Guru86375 points
    Sorry Chris,
    My bad on the /CS comment - can you send along screen captures of the control lines to the ADS1282 so that we can try to reproduce the same conditions you have?
    Tom
    Report Abuse
    • Reply
  • Tom Hendrick
    on Mar 16 2012 19:01 PM
    Guru86375 points
    Hi Chris,
    Have you made any progress here?  Are you able to send the screen shots i asked for?
    Tom
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
