• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS1230 Based Weigh Scale
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 6 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 13 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 26 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
  • Saumitra Deshpande
    Posted by Saumitra Deshpande
    on Feb 28 2012 12:38 PM
    Prodigy80 points
    I've designed ADS1230 based weigh scale. Eveything is working ok(minor glitch of ISP is solved, thanks ot Bob), display is stable.
    My configuration is, Load Cell Capacity = 20kg, Excitation=ADCref=5V, PGA=64 , 10SPS. Avaraging is simple 2 sample avaraging, nothing special.
    I am posting some images which display plots of internal raw adc readings and avaraged readings. These plots are created using Python+Matplotlib sampled over USB.
    I would like to know how much improvement is possible(or required) through,
    a) Software : Moving filter avging with more samples b) Hardware: Layout improvements. Moving to PGA=128
    My aim is to get 10mg resolution with a 300gm Load Cell with the same board. As per my calculations it seems possible.
    Any suggestions ? Thanks in advance.
    _Saumitra
    1) Only Pan. For this Display = 0.00 kg.
    2) Pan+500gm. This my Calibration Weight, Display = 0.500 kg
    3) Pan+Random Weight, Display = 5.274 kg
    4) Pan+Random Weight. Display = 14.040 Kg
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Bob Benjamin
    Posted by Bob Benjamin
    on Feb 29 2012 12:31 PM
    Mastermind33935 points
    Saumitra,
    It appears that your response is pretty good with the averaging at 2.  Increasing the averaging will delay the response significantly, and depending on the type of noise may not help all that much more.  I would doubt that going beyond 4 averages would be that helpful.
    Increasing gain will increase the noise, but it will also increase the resolution.  The measure to use is really noise free bits achieved.  There should be some improvement by going to a gain of 128, even in your current load cell.
    For the new load cell you should be able to get the same ratio of resolution as you are getting with the existing load cell.
    Bob B
    ADS1230
    Report Abuse
    • Reply
    on Feb 29 2012 23:39 PM
    Prodigy80 points
    Bob,
    I concluded the same. Unfortunately on my current board, I don't have facility to switch to gain of 128, pin is tied to GND. Although I am satisfied with current result. May be I'll spin another board, just to check the improvement in resolution :)
    Thanks any way for the reply.
    _Saumitra
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
