• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS8363 Differential signal
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 1 day ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 7 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 14 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is answered
Basavaraj Hiremath
Posted by Basavaraj Hiremath
on Mar 21 2012 11:15 AM
Intellectual530 points
I am trying to convert a single sided signal into differential signal and use ADS8363 (EVM) to sample. My signal is 0-5v range but after the ADC I get only half range signal.
I7455.SCAN0001.PDF have attached a pdf file showing my connections.
What am I missing?
Thank you.
Basu
ADS8363 adc Differential
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kevin Duke
    Posted by Kevin Duke
    on Mar 21 2012 14:37 PM
    Verified Answer
    Verified by Kevin Duke
    Mastermind18245 points
    Hi Basavaraj,
    Lets start by looking at the full scale input range of the ADS8363 (+/- VREF), in your case +/- 2.5V. The circuit you have around the THS4131 right now will differentially create a 5V signal on the input of the ADS8363 when VS swings to 5V. You could change VREF to 5V to fix this, but you would still only be operating over half the range of the ADS8363.
    To utilize the entire range of the ADS8363 we need to look at the circuit you have around the THS4131. Right now you have the negative terminal at ground and your 0-5V signal on the positive terminal. This is always going to yield an output that swings from 0-5V differentially - see the simulation below for clarification:
    If, instead, you apply 2.5V at the negative terminal of the op amp we get an output that does swing positive and negative (differentially) that should work with a 2.5V reference on the ADS8363, in fact this configuration will maximally utilize the resolution of the ADS8363. See below:
    This should fix your problem.
    Edit: Modified the simulation axis to make this more clear
    Kevin Duke
    Precision DAC Applications
    Report Abuse
    • Reply
  • Christopher Hall
    Posted by Christopher Hall
    on Mar 21 2012 15:56 PM
    Verified Answer
    Expert6730 points
    Hi Kevin,
    I like your solution. I had thought of using a 5V reference as well but the ADS8363 only takes 0.5V to 2.525V reference. I might also suggest just using a single-ended input and bypassing the THS4131 altogether (buffering the signal if necessary):
    This is also a +/-2.5V signal, when referenced to 2.5V.
    Chris
    Christopher Hall | Δ-Σ Data Converter Applications
    TI.com | Selection Guide | Technical Documents | Tools & Software | Design Notes | E2E Site Map
    Report Abuse
    • Reply
  • Kevin Duke
    on Mar 21 2012 16:20 PM
    Christopher Hall
    A fair catch! I fell victim to just checking the ABS MAX table.
    Should this scheme be implemented I would be carefully aware of buffering architectures on the reference voltage/negative input. Since this is a SAR and the input impedance on the negative terminal is non-static I could see potential impact on the reference voltage depending on the drive strength of the buffering amplifier from the reference source. It may be no concern, but I have not tried such a configuration before.
    Kevin Duke
    Report Abuse
    • Reply
  • Basavaraj Hiremath
    on Mar 23 2012 16:03 PM
    Hello Kevin and Christopher,
    Thank you for the replies. We have tried Christopher's solution and it works. But we would like to have the buffer between ADC and our system. We will try Kevin's solution and update you guys.
    Thank you again.
    Basu
    Report Abuse
    • Reply
    on May 01 2012 14:17 PM
    Hello Kevin and Chritopher,
    This solution (shown in simulation figures) seems to work. But I have my signal connected to the positive input not to the negative input as shown in the simulation. Am I missing something here? There is also a shift 300mv in the peak signal value. May be this is coming of resistors (1% resistors used)?
    Thank you.
    Basu
    Report Abuse
    • Reply
  • Kevin Duke
    on May 01 2012 15:14 PM
    Basavaraj,
    Can you deliver a scope capture of this drift? Additionally, how are you deriving the voltages to drive the Vocm and the negative terminal? Maybe probe these voltages as well to ensure that they are where you expect and not drifting. If you're using 1% resistors and the values in the simulation I don't think you could get a shift of such magnitude...more like ~50mV.
    Kevin Duke
    Report Abuse
    • Reply
    on May 01 2012 17:42 PM
    I am using voltage divider for both. I will switch to 2.5v regulators and see if that helps.
    I will try to get some scope captures tomorrow.
    Thank you.
    Basu
    Report Abuse
    • Reply
  • Kevin Duke
    on May 02 2012 10:09 AM
    Basavaraj,
    When you post your scope captures please also include a complete schematic for the relevant sections of your design for this problem. I'd like to assume as little as possible so we can get your problem solved quickly!
    Kevin Duke
    Report Abuse
    • Reply
    on Jun 11 2012 09:41 AM
    Verified Answer
    Hello Kevin,
    We have the amplifier and ADC working. It needed a clean 2.5v reference and we were not providing it earlier. After we used a 2.5V regulator, we are getting a much better signal.
    Thanks for all the help.
    Basu
    Report Abuse
    • Reply
  • Kevin Duke
    on Jun 11 2012 09:50 AM
    Basavaraj,
    Happy to help, let us know if anything else comes up.
    Kevin Duke
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
