• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS7946 ENOB beyond 100 KHz
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 1 day ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 9 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 16 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is answered
John Carroll103403
Posted by John Carroll103403
on Apr 12 2012 03:41 AM
Prodigy80 points
I'm looking for some information for the ADS7946 ENOB or SNR up to 1MHz.  The datasheet only specifies the SNR to 100 KHz....
My application uses an Fclk=2M.  Any data or help estimating this would be helpful.
John
ADS7946
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tony Calabria
    Posted by Tony Calabria
    on Apr 12 2012 16:32 PM
    Verified Answer
    Verified by John Carroll103403
    Mastermind42750 points
    Hi John,
    Are you running at a 2MHz SCLK? If so, your not running a clock fast enough to read back data fast enough to read back a 1MHz sine wave. With a 2MHz SCLK, your throughput will be on the order of a couple hundred kSPS in which Nyquist limits your input signal that you can record to about 100 to 150kSPS. You will need a faster SCLK to digitize a sine wave of 1MHz.
    Tony Calabria
    Report Abuse
    • Reply
  • John Carroll103403
    on Apr 13 2012 01:48 AM
    Verified Answer
    Prodigy80 points
    Hi Tony,
    My mistake, I ment to write we were planning on sampling at 2MSPS.  SCLK is 40 MHz.  Is there any SNR or ENOB information available above 100KHz?
    John
    ADS7946
    Report Abuse
    • Reply
  • Tony Calabria
    on Apr 19 2012 11:03 AM
    Verified Answer
    Hi John,
    Is their a specific frequency that you are interested in? 200KHz, 300KHz....
    I can run a test with a sine wave of that frequency to try to get you some baseline numbers.
    Tony Calabria
    Report Abuse
    • Reply
    on Apr 20 2012 03:59 AM
    Verified Answer
    Prodigy80 points
    Hi Tony,
    That would be great!  Could you please look at 250 KHz, 500 KHz,  and 750 KHz?
    Thanks again,
    John
    Report Abuse
    • Reply
  • Tony Calabria
    on Apr 20 2012 14:25 PM
    Verified Answer
    Verified by Tony Calabria
    Hi John,
    Here is the data I was able to collect for you. There was not a coherent frequency anywhere around 750KHz so there is not a way for me to get an accurate answer for you on that input frequency. I am a little concerned that I was running into the performance of the function generator that we had. I usually use a multiple order band pass filter to help filter the input signal prior to the ADC but we do not have a 250KHz and 500KHz block filter available. 250K and 500K are on the fast end for a 2MSPS data converter but still do show nice results. Keep in mind that at these speeds, the data only records 8 / 4 data samples per sine wave period.
    Tony Calabria
    Report Abuse
    • Reply
    on Apr 23 2012 04:37 AM
    Prodigy80 points
    Tony,
    Thanks!  The data provided will be helpful.
    John
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
