• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ads1256- msp430f5438a interface
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 6 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 13 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 26 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is answered
Kedar Joshi
Posted by Kedar Joshi
on Apr 13 2012 16:42 PM
Intellectual305 points
Below is a part of the code I wrote to interface ADS1256 with MSP430F5438A. I am using msp430 at frequency of 16 MHz. the interfacing is done using spi interface. and I am using
smclk/4 for spi Sclk. I am not able to read back the registers of ads, when initializing the adc in the adc_spi_init routine. The Smclk after boosting up to 16 MHz not of a good
shape. but I need to use this high freq for MCLK  for carrying out some filtering on the incoming data. So I do not want a lesser frequency for SPI comm. Can anyone suggest
help me out with this. as SPI interface is not working.
int i=0;
int ADC_init_flag=0;
int first_data=0;
char test;
void MCU_USB_init();
void ADC_spi_init();
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
// P1.0 LED for signalling
P1DIR |= 0x03; // Set P1.0 to output direction
// P!.4 enabled to recieve interrupt from DRDY of ads1256
P1OUT|=0X10;
P1REN |= 0x10; // Enable P1.4 internal resistance
// setting up clock to operate at 16 MHz
P1IE |= 0x10; // P1.4 interrupt enabled
P1IES |= 0x10; // P1.4 Hi/Lo edge
P1IFG &= ~0x10; // P1.4 IFG cleared
P1SEL |=0x40;
//ACLK = ~32.768kHz, MCLK = SMCLK = DCO ~ 16MHz. BRCLK = SMCLK/2
P11DIR |= 0x07; // ACLK, MCLK, SMCLK set out to pins
P11SEL |= 0x07; // P11.0,1,2 for debugging purposes.
UCSCTL3 |= SELREF_2; // Set DCO FLL reference = REFO
UCSCTL4 |= SELA_2; // Set ACLK = REFO
__bis_SR_register(SCG0); // Disable the FLL control loop
UCSCTL0 = 0x0000; // Set lowest possible DCOx, MODx
UCSCTL1 = DCORSEL_5; // Select DCO range 24MHz operation
UCSCTL2 = FLLD_1 + 488; // Set DCO Multiplier for 12MHz
// (N + 1) * FLLRef = Fdco
// (366 + 1) * 32768 = 12MHz
// Set FLL Div = fDCOCLK/2
UCSCTL5 |= DIVA_1; // ACLK=16/2= 8MHz
__bic_SR_register(SCG0); // Enable the FLL control loop
// Worst-case settling time for the DCO when the DCO range bits have been
// changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx
// UG for optimization.
// 32 x 32 x 16 MHz / 32,768 Hz = 500000 = MCLK cycles for DCO to settle
__delay_cycles(500000);
// Loop until XT1,XT2 & DCO fault flag is cleared
do
UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + XT1HFOFFG + DCOFFG);
// Clear XT2,XT1,DCO fault flags
SFRIFG1 &= ~OFIFG; // Clear fault flags
}while (SFRIFG1&OFIFG); // Test oscillator fault flag
ADC_spi_init();
// USB/UART interface with hyperterminal
MCU_USB_init();
__bis_SR_register(GIE); // Enter w/interrupt
while(1);
// MSP430_UART interface init
void MCU_USB_init()
{// WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P10SEL = 0x30; // P10.4,5 = USCI_A3 TXD/RXD
UCA3CTL1 |= UCSWRST; // **Put state machine in reset**
UCA3CTL1 |= UCSSEL_1; // CLK = ACLK
UCA3BR0 = 0x03; // 32kHz/9600=3.41 (see User's Guide)
UCA3BR1 = 0x00; //
UCA3MCTL = UCBRS_3+UCBRF_0; // Modulation UCBRSx=3, UCBRFx=0
UCA3CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
UCA3IE |= UCRXIE; // Enable USCI_A0 RX interrupt
__delay_cycles(100); // Wait for slave to initialize
// ADC_MSP430 SPI interface initialization
void ADC_spi_init()
// SPI interface between ADC and MSP using port A0 (port 3)
//ACLK =8 MHz MCLK = SMCLK = DCO ~ 16MHz. BRCLK = SMCLK/4=4Mhz
P10DIR|=0x03; // for reset and chip select
P10OUT|=0x03;
__delay_cycles(100); // reset pulse of atleast 4 cycles
P10OUT =0x00;
P10OUT|=0x02;
P3SEL |= 0x31; // P3.5,4,0 option select
UCA0CTL1 |= UCSWRST; // **Put state machine in reset**
UCA0CTL0 |= UCMST+UCSYNC+UCMSB+UCCKPL; // 3-pin, 8-bit SPI master
// Clock polarity high, MSB
UCA0CTL1 |= UCSSEL_2; // SMCLK
UCA0BR0 = 0x04; // /4
UCA0BR1 = 0; //
UCA0MCTL = 0; // No modulation
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
UCA0IE |= UCRXIE; // Enable USCI_A0 RX interrupt
// setting parameters of ADC
i=100;
// while (i>0)
//P1OUT^= BIT1;
//i--;
ADC_init_flag=1;
UCA0TXBUF=0x50; //WREG to ADC
while(!(UCA0IFG&UCRXIFG)); // Wait for transmission
UCA0TXBUF=0x04; //5 Registers to be written(4+1)
__delay_cycles(50000);
UCA0TXBUF=0x01; // Status reg MSB first
UCA0TXBUF=0x01; // MUX AIN0 Pos and AIN1 Neg i/p
UCA0TXBUF=0x00; //ADCON all default
UCA0TXBUF=0xB0; //Drate 2KHz
UCA0TXBUF=0x00; //GPIO all default
UCA0TXBUF=0xF0; //GPIO all default
UCA0TXBUF=0x10; // read reg status
UCA0TXBUF=0x00; // read 1 reg
test=UCA0RXBUF;
__delay_cycles(50000); // Wait for slave to initialize
// Minimum 2ms.
SPI ads1256 MSP430 adc ADC problem
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tom Hendrick
    Posted by Tom Hendrick
    on Apr 14 2012 08:23 AM
    Guru86200 points
    Hi Kedar,
    Welcome back!  How did you make out with the ADS1224?  Part of the problem you are having with this current ADS1256 setup may be related to the SPI settings you are using with the MSP430F5438.  You are setting the UCCKPL bit which will make the SCLK dwell high.  You are also leaving the UCCKPH bit cleared, which means data is strobed on the rising SCLK edge.  If you look at Figure 1 in the ADS1256 data sheet, you'll notice that the clock polarity and phase requirement is opposite from your current MSP430 setup.  Try removing the '+ UCCKPL" in your SPI setup and let us know if you get better results.
    UCA0CTL0 |= UCMST+UCSYNC+UCMSB; // remove this to keep the SCLK dwelling low +UCCKPL;
    Tom
    Report Abuse
    • Reply
  • Kedar Joshi
    on Apr 14 2012 12:35 PM
    Hi Tom,
    Thank you for  you reply. The replacement for ads1224 worked very well, thanks for that as well. I am now working on ADS1256.  I made the changes as you said.  Following is the routine with some changes, but I am still not able to read any registers. I checked the SCLK and SIMO wave forms on oscilloscope and also on watch window, and it is right from MSP430 side but the SOMI is still all zeros with some noise. Can you suggest something?  Do you think I can check some testpoints on ads1256EVM?
    void ADC_spi_init()
    P10DIR=0x02; // for reset and chip select
    P10OUT|=0x02;
    P10OUT =0x00;
    __delay_cycles(10000); // reset pulse of atleast 4 cycles
    P10OUT|=0x02;
    UCA0CTL0 |= UCMST+UCSYNC+UCMSB+UCCKPH; // 3-pin, 8-bit SPI master
    UCA0CTL1 |= UCSSEL_1; // ACLK
    UCA0BR0 = 0x01; // 1
    UCA0BR1 = 0; //
    UCA0IE |= UCRXIE+UCTXIE; // Enable USCI_A0 RX interrupt
    i=100;
    // while (i>0)
    //P1OUT^= BIT1;
    //i--;
    ADC_init_flag=1;
    while(1)
    //status
    while(!(UCA0IFG&UCTXIFG)); // Wait for transmission
    UCA0TXBUF=0x00; //5 Registers to be written(4+1)
    __delay_cycles(200); // 50 Tclkin for adc cycles delay
    //test2=UCA0RXBUF;
    test1=UCA0RXBUF;
    // MUX
    UCA0TXBUF=0x53; //WREG to ADC
    UCA0TXBUF=0xB0; // MUX AIN0 Pos and AIN1 Neg i/p
    UCA0TXBUF=0x13; // read reg status
    // __delay_cycles(200); // 50 Tclkin for adc cycles delay
    test2=UCA0RXBUF;
    Report Abuse
    • Reply
  • Tom Hendrick
    on Apr 14 2012 12:56 PM
    Guru86200 points
    Can you send some screen shots along?  I suspect you have things wired between the two EVAL boards again, have you double checked you connections?
    Tom
    Report Abuse
    • Reply
  • Kedar Joshi
    on Apr 14 2012 15:05 PM
    Hi, followings is the scope shot with sclk and simo, where you can see green sclk and yellow simo. Here I am having some issues, as you can see the delay between the two sclks for different data bytes is 200us, while in code, I am giving delay of 5000 cycle with mclk 16MHz, so it should have been close to 300us. also the scope plot below this is with somi.  where you can see th noise. I verified the connections, and attached the copy of my connection diagram0334.3659_001.pdf and my code snippet
    void ADC_spi_init()
    P10OUT|=0x02;
    P10OUT =0x00;
    P10OUT|=0x02;
    UCA0CTL0=0x00;
    UCA0BR1 = 0; //
    i=100;
    // while (i>0)
    //P1OUT^= BIT1;
    //i--;
    ADC_init_flag=1;
    while(1)
    //status
    __delay_cycles(5000);
    __delay_cycles(5000); // 50 Tclkin for adc cycles delay
    __delay_cycles(50000); // 50 Tclkin for adc cycles delay
    //test2=UCA0RXBUF;
    test1=UCA0RXBUF;
    // MUX
    test2=UCA0RXBUF;
    Report Abuse
    • Reply
  • Tom Hendrick
    on Apr 14 2012 15:25 PM
    Guru86200 points
    Hi Kedar,
    Now the clock phasing is off.  The MSP430 is a little different in the way it defines CKPH from other processors.  It looks like you changed UCCKPL to UCCKPH, so now the data is valid on the rising SCLK edge by your screen shot - it need to be valid on the falling.
    Change this: UCA0CTL0 |= UCMST+UCSYNC+UCMSB+UCCKPH;
    To this: UCA0CTL0 |= UCMST+UCSYNC+UCMSB; and let us know if that clears up the issues you are having.
    Tom
    Report Abuse
    • Reply
  • Kedar Joshi
    on Apr 14 2012 15:51 PM
    I am sorry, I sent you the wrong code. UCCKPH is off
    that line is :
    Report Abuse
    • Reply
  • Kedar Joshi
    on Apr 14 2012 15:53 PM
    I edited the code, and now the waveforms are correct by clock edge, where I am sending the data on rising edge, but still there is no data on somi.
    Report Abuse
    • Reply
  • Kedar Joshi
    on Apr 14 2012 16:42 PM
    also I wanted to know about the clock. Right now I am using SCLK at 32,768Hz and I want to increase it, but before that, The MCLK and SMCLK generated by the system are very poor at 16 MHz, the shape is far worse than a sqaure wave, is there any way to improve that?
    Report Abuse
    • Reply
  • Kedar Joshi
    on Apr 16 2012 17:20 PM
    Verified Answer
    Verified by Tom Hendrick
    I solved the problem, The problem was with some connections and after I modified them, I got it working. While running the code I observed some weird behavior with ADS1256. Reading the values from the DRATE register in a while(1) loop for debugging gave some erratic values. Even though a single value was written to it. and on reset the default value of status register I get is 0x30 rather that 0xX1, what can be the reason?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
