• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » Analogue to digital converter using ADS1158 and PIC 24EP512GU810
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 7 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 14 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 27 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is answered
Ronnie Adkins
Posted by Ronnie Adkins
on Apr 16 2012 13:32 PM
Prodigy50 points
I intend to make a precision Analogue to digital converter using ADS1158 and PIC 24EP512GU810. As I am a novice in this area and have never used the these devices, I do have a few questions before I purchase them.
1.  Does the ADS1158 require any sort of programming? Or would it involve in just sending a word to the ADS1158 and it would perform the conversion.
2. For measuring 16 channels, would it be possible to measure a 300hz input signal accurately (i.e. within +/- 0.00001 volts).
3 Can the  PIC 24EP512GU810 be programmed using the PIC kit 3?
It would be great to know the above details, as I these doubts popped up after I read the data sheets.
Thank you
ADS1158 A/D converters adc ADC problem ADS115 PIC 24EP512GU810 Precision Data Converters
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tom Hendrick
    Posted by Tom Hendrick
    on Apr 16 2012 22:53 PM
    Verified Answer
    Verified by Tom Hendrick
    Guru86200 points
    Hi Ronnie,
    Welcome to our forum!  Can you provide any additional detail here with respect to your ADS1158 hardware and your reference voltage?  Are you using our evaluation module or your own PCB?  We can better address your second question with this detail.
    For your other questions, the ADS1158 does not require programming if your application is comfortable with the deault settings of the device.  We do not have any direct experience with the PIC kit 3, but if you can control an SPI port from your processor, I don't see where there would be any issues.
    Tom
    Report Abuse
    • Reply
  • Ronnie Adkins
    on Apr 17 2012 01:26 AM
    Prodigy50 points
    Hi, Tom,
    Thank you so much for taking your time to answer my query. I would be using my own PCB, but wold that make the device any less accurate?
    I am pretty much in a hurry to build the device, but have come to realise that the 48 pin IC base is not available in the local market. Are there any  other ways by which I can mound the device on the PCB?
    Thank you
    Ronnie
    Report Abuse
    • Reply
  • Tom Hendrick
    on Apr 17 2012 18:55 PM
    Verified Answer
    Guru86200 points
    Hi Ronnie,
    We're here to help!  Using your own PCB won't impact the absolute accuracy of the ADS1158 itself, but the things you put around it (the reference, the grounding structure, how you have your inputs routed) can certainly have an impact on accuracy.  Send us your schematic and we'll be happy to review it for you.
    By 48 pin IC base, do you mean a socket or are you looking for a pre-fabricated board that you can mount the chip to?  If it's the later, you can try searching Proto Advantage or Digikey.
    Tom
    Report Abuse
    • Reply
  • Ronnie Adkins
    on May 11 2012 03:48 AM
    Prodigy50 points
    Dear Tom,
    Thank you very much for your reply.
    I do have another question for you how do I check if the ADS 1158 is working, without connecting the analogue signal inputs and not SPI communications?
    I have made the following connections to check it:
    AVDD, VREFP, DVDD, PWDN (bar), RESET (bar) connected to 5v.
    AVSS, VREFN, DGND, CLKSEL, AINCOM connected to Ground.
    XTAL1 and XTAL2 connected to a crystal.
    When I check the out waveform at pin CLKIO (pin 13) there no clock waveform present. What do you think is the possible problem? Was it the right approach to check the device?
    Thank you
    Ronnie
    Report Abuse
    • Reply
  • Ronnie Adkins
    on May 11 2012 03:49 AM
    Prodigy50 points
    p.s. I have also connected the required capacitors.
    Report Abuse
    • Reply
  • Tom Hendrick
    on May 12 2012 08:12 AM
    Guru86200 points
    Hi Ronnie,
    By your description above, I believe there should be a clock output from the ADS1158.  What crystal are you using and what capacitor values do you have?
    Tom
    Report Abuse
    • Reply
  • Ronnie Adkins
    on May 19 2012 03:20 AM
    Prodigy50 points
    Dear Tom,
    Apologies for for the late reply, its just that I get time only over the weekends to work on the ADS.
    I do believe the problem with the ADS not having an output clock waveform was due to the fact that I had not enabled the CLKENB bit. So I had to interface it with a microcontroller before I got an output waveform.
    But now I have another problem:
    I have set the reference voltage as 5v and 0v and am using it in unipolar mode. I do believe that for a 5v input I should get a FFFF and 0 volt a 0000.
    But the problem is that the voltage is being divided by 2. So, I am getting a 7FFF for a 5 volt input.
    What do you think the problem could be?
    Thank you
    Ronnie
    Report Abuse
    • Reply
  • Tom Hendrick
    on May 19 2012 09:52 AM
    Guru86200 points
    Hi Ronnie,
    The output code of the ADS1158 is in binary two's compliment format.  Take a look at Table 7 on page 23 of the data sheet, your conversion result for 5V in is correct - it should be 0x7FFF.
    Tom
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
