• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » Re: ADS1247 RTD Measurement
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 5 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 12 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 25 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
  • Michele Bertoni
    Posted by Michele Bertoni
    on Apr 19 2012 08:24 AM
    Prodigy10 points
    Hi, I'm a newby about ADC measurements....
    I would like to use an RTD system: if I use an RTD as voltage divider with internal reference voltage ADC I have a measure depending of RTD value (temperature) and power supply.
    So I need to measure also power supply.
    So, to avoid this (measure not affected by power supply value) do I need to power RTD through Vref or constant current generator, similar to application report "Temperature measurement applications using the ADS1247 and ADS1248", Figure1?
    Thanks.
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Luis Chioye
    Posted by Luis Chioye
    on Apr 19 2012 17:04 PM
    Genius17435 points
    Hi Michele,
    I split  your post  from the original older thread since this is a different question.
    In general, when designers measure a RTD or thermistor with an ADC on a voltage divider configuration, they use the excitation voltage (voltage supply) as a voltage reference for conversion.  The user is then required to know the value of the series resistor in the voltage divider in order to solve for the RTD value.  Since the voltage supply is used as a voltage reference and also to excite the RTD sensor,  this configuration creates a ratiometric measurement, where any noise and/or drift of the excitation voltage creates a proportional change in the reference signal path and the input signal path.  Since the change is seen both at the reference path and signal path, any errors due to drift of the excitation and some of the low frequency noise tends to cancel.   In the ratiometric configuration, where the excitation voltage is used for reference,  the user does not need to measure the excitation voltage, however, is required to know accurately the value of the series resistor used in the voltage divider with the RTD.
    -- In the case of the ADS1247/ADS1248, the device is optimized to be used on the recommended configurations for the 2-wire, 3-wire and 4-wire shown in the application note "Temperature measurement applications using the ADS1247 and ADS1248" as you have mentioned on your post above.  The device provides programmable current sources (IDACs) that are used to excite the sensor. These are also ratiometric configurations, where the IDAC current is used to excite the RTD and to generate the voltage reference accross RBIAS resistor.  Similar to the case with the voltage divider configuration above, the user is not required to measure the excitation current, however, in order to solve for the RTD value,  the user is required to know  the value of the RBIAS resistor.  Therefore, the RBIAS resistor must be an accurate/low drift resistor.
    The easiest way to configure the ADS1247/48 to measure RTD's will be to use the IDAC currents as recommended on the application note, since this configuration is also ratiometric, where both inputs of the device are biased at the optimal common-mode voltage range and allows the use of additional gain by using the ADS124x internal Programmable Gain Amplifier (PGA) to increase resolution...
    Thank you and Best Regards,
    Luis
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
