• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ads1298 wrong samples
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 3 days ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 11 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 19 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
  • Maximiliano Cordoba
    Posted by Maximiliano Cordoba
    on Apr 23 2012 08:55 AM
    Prodigy40 points
    Hi people from TI
     I´m  Maximiliano from Argentina, and I´m trying to use the ads1298 in an ECG project for my University.
    I´m facing big problems when trying to read the samples from the ads1298, since they appear to be quite noisy. I attached an excel file with 400 samples of a 10 Hz triangular wave, and you could see that it seems to be tracking it but really not in a nice way at all. The ads1298 is configured in 500 SPS, and i'm reading channel0 with gain 3.
    I would appreciate some help, have somebody face any problem like these?
    I´m working with stm32f1xx microcontrollers, in CooCox using gcc.
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Tom Hendrick
    Posted by Tom Hendrick
    on Apr 23 2012 09:30 AM
    Guru86220 points
    Hi Maximiliano!
    Welcome to our forum!  This looks like there might be an error in your SPI communication setup with the ADS1298.  Can you post any screen shots from an oscilloscope that shows your SDCLK, SDI and SDO?  Is this your own hardware that you've built or are you trying to wire your controller into the ADS1298ECGFE-PDK hardware?
    Tom
    Report Abuse
    • Reply
    on Apr 23 2012 10:39 AM
    Prodigy40 points
    Hi Tom, thanks for answering so quickly
    I have built two different circuits, both with the same microcontrolker and spi rutines.
     I would like to give you those screen shots, but since only have a two channel oscilloscope, i will show you only SDI (MISO) and SDCLK. However SDO is always on a low level because my dummy data to read the ads1298 is always 0x00;
     the yellow signal is the sdclk and the red one is the SDI.
    These capture is taken when a data ready is read. they correspond to the status and channel0 signal. i dont understand why there is a pulse in SDI before the first SDCLKs
     Thanks in advance for your help
    Report Abuse
    • Reply
  • Marcos Chaparro
    Posted by Marcos Chaparro
    on Apr 24 2012 05:46 AM
    Prodigy10 points
    Hi fellows, I'm Marcos, and I'm working with Maximiliano in this project.
    Note the shape of the waveform shown in the first post. It looks like there are 10 signals mixed up. I saw another acquisition when it looks like there were 4 signals: 2 sines and 2 dc (almost zero), interleaved in the same way [sine1, sine2, dc1, 0,sine1, sine2, dc1, 0,...], and the original injected signal was a 4Hz sine.
    Also, we just found the SDO pulse in the datasheet, its equivalent to the DRDY, in order to save the DRDY connection to the MCU.
    Unfortunately, I blew the MCU because of a power supply failure; I was trying to see if the MISO data was steady enough (I was applying a constant voltage to the ADC).
    I guess we'll come back in a couple of days, when I fix the damaged components of the board.
    Best regards
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 06 2012 13:45 PM
    Guru86220 points
    Hi Max and Marcos,
    How are you making out here?  Have you resolved your issues?
    Tom
    Report Abuse
    • Reply
  • Alberto Tablon
    Posted by Alberto Tablon
    on Aug 12 2012 01:30 AM
    Prodigy60 points
    Hey marcos and Maxi, my name is Alberto. I'm also from Argentina and I think that i have the same problem as you with a sin waveform of 10Hz. For example, here is a picture from matlab:
    I made a previous post with where I described in which way I worked to get that signal.
    http://e2e.ti.com/support/data_converters/precision_data_converters/f/73/t/207376.aspx
    Do you think that this is because of some problem in the spi interface? With a DC input I had no problem that's why i thought that the connection couldent be. But I've no idea what happens.
    Thanks for your time. Regards,
    Alberto
    Report Abuse
    • Reply
    on Aug 26 2012 10:58 AM
    Prodigy40 points
    Hi Tom
    We are still facing problems, no we think that most of them are because ofelectronic noise. I would appreciate any recommendation you could give me.
    It would be nice to  see examples of using this IC besides the development kits.
    Maximiliano
    Report Abuse
    • Reply
  • Johann Meier
    Posted by Johann Meier
    on Aug 27 2012 03:58 AM
    Prodigy70 points
    Maximiliano Cordoba
    Here is an project with the ADS1298:
    http://code.google.com/p/opendous/wiki/BioSensorPlatform
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
