• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » Differential and single-ended modes in ADS1298
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 1 day ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 7 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 15 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is answered
Alexander Uvarov
Posted by Alexander Uvarov
on Apr 27 2012 07:45 AM
Prodigy250 points
Hello!
Could you help me with understanding few points about an analog inputs in ADS1298?
1. As it's described in the datasheet, the input differential mode is preferable for use rather than single-mode. What exact advantages does that have? And what is disadvanteges of single-mode connection?
2. In the schematics for ADS1298 EVK the not installed resistors R58-R66 are used for driving the additional constant voltage to all the input lines. Does that mean the necessity of adding an offset voltage to analog inputs for proper operating of PGAs and ADCs?
3. In my application I want to calculate the ECG leads by PC program using recorded signals from all the electrodes. I'm trying to understand is there any difference between signals combinatting in digital and analog domains? I mean does that affect CMRR or another parameters?
Regards, Alex.
ads1298 differential mode single-ended mode
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tony Calabria
    Posted by Tony Calabria
    on Apr 27 2012 10:44 AM
    Verified Answer
    Verified by Alexander Uvarov
    Mastermind42820 points
    Hi Alex,
    Answers below:
    1. Couple comments for this question. ADC range is +/-Vref and the best way to utilize the entire range is to use a differential input signal. Although, there are ways to use the range in a single ended mode through biasing the negative (-) input. A differential input signal allow you to keep a fixed common mode (CM) voltage which helps with noise reduction and CMR versus a single ended measurement which has a changing CM voltage. Depending on what you are trying to do with measuring ECG, a differential versus single ended measurement would fit.
    2. Depending on your design, you may not need these resistors. Being an evaluation platform, we included pads for many not installed parts to allow customers to experiment. The idea of having the weak pull up and pull down resistors at the input are used to bias the input pins within the ADC's input range. Otherwise, if the input source (patient) is connected without using a RLD electrode, it may be at a different DC bias point from the ADC.
    3. Could you elaborate more on this question. I am not sure what you are asking.
    Tony Calabria
    Report Abuse
    • Reply
  • Alexander Uvarov
    on Apr 27 2012 22:49 PM
    Prodigy250 points
    Hello, Tony. Thank you for answering questions. Comments for third one is following.
    Usually ECG leads are made of combining of input signals using aoperations in analog domain. Another way is to digitize original signals and to combine them in digital domain. The second approach is much more flexible if different systems of leads are required. But I’m worry about CMR reducing - is it such effective in digital domain as in analog? It's kind of dillemma for me.
    With regards, Alex.
    Report Abuse
    • Reply
  • Tony Calabria
    on Apr 30 2012 10:57 AM
    Verified Answer
    Hi Alex,
    Thanks for the additional information, I understand what you mean. We recommend using analog techniques to help improve the CMR. One way we have shown this is using the RLD is a closed loop configuration as shown in the following application note. Give this guy a read -
    http://www.ti.com/lit/an/sbaa188/sbaa188.pdf
    Tony Calabria
    Report Abuse
    • Reply
  • Alexander Uvarov
    on May 01 2012 22:30 PM
    Prodigy250 points
    Thanks a lot!
    This info is very important and useful for me.
    Regards, Alex.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
