• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » About working with ADS8556
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 2 days ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 10 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 17 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is answered
linda rajo
Posted by linda rajo
on May 01 2012 15:09 PM
Prodigy60 points
I am using A/D (ADS8556) from your products and I connect 2 A/Ds in Daisy-Chain mode.I use them in hardware mode. I have a question about A/D in serial mode.when I change the Convert pin from 0 to 1, I desire the Busy Pin changes from 0 to 1 but it doesn't happen.How can I ensure that the A/D works correctly in serial mode?? I use Regulator (REF5025) for providing refrence voltage 2.5 volt for A/D but the output of this regulator is 2.88 V instead of 2.5V.Why it isn't 2.5 volts.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kevin Duke
    Posted by Kevin Duke
    on May 01 2012 15:28 PM
    Verified Answer
    Verified by linda rajo
    Mastermind18035 points
    Linda,
    Can you share some more information about your hardware? Your schematic and/or layout would be a great start.
    Kevin Duke
    Precision DAC Applications
    Report Abuse
    • Reply
  • linda rajo
    on May 06 2012 15:42 PM
    Prodigy60 points
    Dear Kevin ,
     hi
    thank you for your response ,I had lots of problem by attaching my docs ,Finally I could attache the Zip file of schematic and PCB of my board to this message ,
    Hope to be useful
    Best Regards
    Linda6036.attachments_2012_05_05.zip
    Report Abuse
    • Reply
  • Kevin Duke
    on May 07 2012 11:30 AM
    Verified Answer
    Verified by Kevin Duke
    Linda,
    I do not have the appropriate software to view your layout, but I've got a few follow up questions along with some suggestions...
    1. Where is the controller in this set-up? Is it on another board or is it part of this board? If it is on another board, is there a quality ground connection?
    2. On this schematic I do not see where AGND and DGND are tied together - this could be related to BUSY not toggling and related to the REF5025 output. I might have missed this on your schematic or it could be on another page...
    3. C149 seems pretty large, perhaps consider reducing this. As it is right now it's a bit of time until the cap charges up and takes the ADS8556 out of reset.
    4. Perhaps increase the capacitance at C40
    5. Right now the reference buffer is disabled but you are applying the reference voltage at the REFIO pin of the ADS8556. Observe the block diagram of the ADS8556 on page 1 of the datasheet. Note that the REFIO input goes through a buffer before feeding the converters. Right now you have REFBUF_EN tied high so the reference buffers are disabled. This may be related to the output you see on the REF5025 and it is certainly going to be an issue for actually using the devices.
    Play around with these points and if your issues persist please provide us a few oscilloscope captures - ideally I'd like to see the RESET pin on power up, BUSY with respect to CONVST (I'd like to see the BUSY signal at the pin of the device, not after the logic circuit), and a scope capture of the REF5025 output.
    Not seeing something basic like CONVST/BUSY interaction is usually a pointer to something sneaky & silly - like GND issues, reset issues, and power-down issues. The problem may be sneaky, but we will find it!
    Kevin Duke
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
