• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS1232REF Question
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 7 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 14 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 27 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
ADS1232REF Question
ADS1232REF Question
This question is answered
1654446
Posted by 1654446
on May 01 2012 21:08 PM
Prodigy20 points
Hi, I've purchased a Ti's evaluation board for the AD converter ADS1232 REF and i've been having some problems.
1) When I build the original firmware of ADS1232(version 1.1.0) the compiler displays the following error,
uart.c: In function 'uart_init':
uart.c:27:2: error: 'port4' undeclared (first use in this function)
I'm using the shell cygwin and the last version of mspgcc in Windows XP.
2) When I try download the firmware to ADS1232REF via BSL, the makefile no found the programmer msp430-bsl.  I look everywhere and  can't find
Is there any ideas of what's going on? Any way of solve this problem?
Thank you
ADS1232REF
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Bob Benjamin
    Posted by Bob Benjamin
    on May 02 2012 13:16 PM
    Mastermind34035 points
    1654446,
    Welcome to the forum! You are embarking on a very complicated process.  Basically the compiler cannot find the definition for the MSP430 ports used for the MSP430F449.  There may be something missing in the default path assignments regarding MSPGCC.
    Regarding the downloading of the firmware, there are two methods possible.  The make file uses JTAG, and that requires a JTAG programmer for the MSP430.  The actual call is for a parallel port programmer MSP-FETP430IF.  So unless you have that particular device, you should comment out the line in the make file.
    The actual BSL can be done through the USB connection, but requires a downloader program.  One that can be used requires that the TUSB3410 drivers have been installed.  This was done if you have installed the Labview code that controls the ADS1232REF.  The download program is called Simpleflash and can be downloaded from the ftp site at this location:
    ftp://ftp.ti.com/pub/data_acquisition/ADS1256_on_HPA449/
    Changing the firmware is a very ambitious process, and altering the program should require knowledge and proficiency in the use of freeRTOS.  The ADS1232REF was designed as a reference design for weigh scale applications.  Firmware support of altered code will be minimal, as this system was not designed as a development system.
    Bob B
    ADS1232REF
    Report Abuse
    • Reply
  • 1654446
    Posted by 1654446
    on May 11 2012 07:42 AM
    Verified Answer
    Verified by 1654446
    Prodigy20 points
    Bob,
    That worked perfectly! Thank you very much.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
