• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » Using Oversampling to increase ADC resolution
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 1 day ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 7 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 15 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is answered
Alireza Taghizadeh
Posted by Alireza Taghizadeh
on May 02 2012 05:09 AM
Intellectual380 points
Hi:
I have problem in undemanding theory of using oversampling to increase ADC resolution.
Consider ADS8320 as convertor with 2.5 reference i expect to have 38uV/bit resolution. Imagine that I oversampled at 12800 sps
to achieve final 50sps, I expect 4 bit improvement which means 2.4uV/bit. Now I imagine a sin signal with amplitude of 38uVpp.
I expect count 16 at V peak but while ADC output always remain at zero count how can I take signal out of all zero counts samples!?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kevin Duke
    Posted by Kevin Duke
    on May 02 2012 10:38 AM
    Mastermind18255 points
    Alireza,
    Alireza Taghizadeh
    You cant. To implement something like this you need to modify your ADC reference or gain up the 38uV signal. Right now you're more or less oversampling a 0 bit signal since your input is so small that you cannot detect it. To really take advantage of oversampling you should be using the full resolution (or at least a few hundred codes) of your front end first.
    Converting a 38uVpp sinusoidal waveform with a 16 bit ADC is quite the lofty goal without filtering or applying some gain to the signal.
    You might look at a converter that has more bits to start with and perhaps some internal PGA settings to help you gain up the signal. We have a number of offerings in this area.
    Kevin Duke
    Precision DAC Applications
    Report Abuse
    • Reply
  • Alireza Taghizadeh
    on May 05 2012 23:57 PM
    Verified Answer
    Verified by Alireza Taghizadeh
    Thank you Kevin.
    I have already found partial answer to my question in the following document:
    http://www.ti.com/lit/an/spra461/spra461.pdf
    Decreasing reference voltage is not my solution since I want to to increase dynamic range by oversampling.
    What I was missing was use of additive signal, though implementation of such approach is a great challenge for me!
    I am still looking for more detailed documents on this.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
