• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS1248 Thermocouple
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 1 day ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 8 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 16 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is answered
Ramiro Oliveira
Posted by Ramiro Oliveira
on May 02 2012 11:13 AM
Prodigy20 points
Hello.
I'm trying to use a type-J thermocouple with the ADS1248, but I'm having some difficulties. I know i have to enable the VBIAS on the negative channel, but I'm not sure about IDAC. If i enable it it overflows, if i disable it the values get very unstable. Is there anything I'm missing? I know the hardware should be fine since I'm using this design with a PT100.
Thank you.
ADS1248
Report Abuse
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Luis Chioye
    Posted by Luis Chioye
    on May 02 2012 20:08 PM
    Genius17435 points
    Hi Ramiro,
    Welcome to the forum.  For ungrounded/floating thermocouples, the VBIAS function could be used to bias the thermocouples at the optimal common-mode voltage in the middle of the supplies.  As you mentioned, one of the inputs of the thermocouples will need to be connected to VBIAS, and this works well provided the thermocouple sensor is floating.
    Thermocouple sensors produce their own differential voltage accross their terminals as a function of temperature and they do not require a voltage or current excitation.   RTD's and Thermistors are resistive elements and they require the IDAC current excitation to produce a voltage output.  Are you using the IDAC excitation current for another RTD sensor in the application?  Where are you applying the IDAC current?  Do you have an schematic?
    Attached is an application note of the ADS1118 measuring thermocouples that may give you useful background information on thermocouple measurements.
    http://www.ti.com/lit/an/sbaa189/sbaa189.pdf
    Luis
    Report Abuse
  • Ramiro Oliveira
    on May 03 2012 04:59 AM
    Prodigy20 points
    Thank you for the application note.
    I'm not sure I understand your question. When I want to read a RTD I apply IDAC current on both the negative and the positive input.
    Thank you
    Report Abuse
  • Luis Chioye
    on May 03 2012 11:05 AM
    Verified Answer
    Verified by Tom Hendrick
    Genius17435 points
    On the post above,  you have mentioned that you are trying to measure a J-type thermocouple with the ADS1248 applying VBIAS on the negative channel; however, it mentions that you are not sure about the IDAC.
    One possible way to set up the device to measure an ungrounded thermocouple is to apply VBIAS in one of the terminals and set up the device to perform the conversion using the 2.048V internal reference of the ADS1248 device.  When performing the RTD measurement, the user would typically use the IDAC current to excite the RTD and also place an RBIAS resistor in series between REFP and REFN to generate an external reference in a ratiometric configuration.  The RBIAS resistor is also used in this configuration to bias the RTD at the ideal common-mode voltage close to the middle of the supplies. Please refer to the diagram below.
    Please refer to the link below to an application note where the ADS1248 is performing thermocouples and RTD measurements.
    http://www.ti.com/lit/an/sbaa180/sbaa180.pdf
    Please let me know if you having issues with the RTD or thermocouple measurement; if you have an schematic available, we are happy to review it.
    Thank you and Best Regards,
    Luis
    Report Abuse
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
