• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS1298 SCLK inconsistency or misunderstanding?
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 2 days ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 8 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 16 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is answered
Esteban Valverde
Posted by Esteban Valverde
on May 08 2012 15:23 PM
Prodigy40 points
Hi, I'm sorry. I'm trying to understand real rates, and times when I choose some data rate and the SPI speed in my system.
page 31 on ADS1298 stays that tsclk < tdr / 216 (for 24, 8 channels). That's mean that at 500SPS tsclk < 9.25useg = 110Khz (aprox)
by the other hand
page 15 stays that min tsclk = 50nseg. By extracting 216bits by SPI channel, this means 50 * 216 = 10.8useg
If I don't make a mistake, page 31 stays a speed lower than the minimum speed specified in page 15 for the SPI port ???.
May be, my mistake is not understand what means data rate at all. Is it the speed to obtain one single bit converted or the speed to obtain a group of 24bits converted (the whole analog signal at a single instant) ?
Please, I will appreciate if you can clarify my doubt.
Best regards, Esteban
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tom Hendrick
    Posted by Tom Hendrick
    on May 08 2012 17:06 PM
    Guru86375 points
    Hi Esteban,
    Page 15 is describing the minimum SCLK period (50 or 66.6ns) which is actually the maximum SCLK speed the ADS1298 can tolerate.  Page 31 is describing the minimum SCLK speed you can use to get all data out of the ADS1298.  The 10.8us is equal to taking 216 bits (8 channels plus the status byte) with a 20MHz SCLK.  The inverse of 10.8us is 92.6kSPS, which is nearly 3 times the maximum data rate the ADS1298 can support.
    The data rate is the time period between DRDY pulses.  At the maximum speed or 32000SPS, you would see a DRDY pulse every 31.25us.  Your SCLK has to be fast enough to get all the data out of the device before another DRDY pulse comes along.
    Tom
    Report Abuse
    • Reply
  • Esteban Valverde
    on May 09 2012 08:12 AM
    Verified Answer
    Verified by Tom Hendrick
    Prodigy40 points
    Thanks Tom, I think I get it.
    So, you said: "The data rate is the time period between DRDY pulses.  At the maximum speed or 32000SPS, you would see a DRDY pulse every 31.25us".
    Because in the ADS1298 the eight Delta-Sigma ADC are in paralell mode, that means I've the eight 24bits-channels with valid data ready to be read by the SPI port every 31.25us. So, I must to use a SCLK faster than 31.25us to read them all without missing data. If I understood well right, the minimun tSCLK must be 31.25us / 216 = 145ns which is equal to use a fSCLK faster than 6.912Mhz, isn't it ?
    berst regards, Esteban
    Report Abuse
    • Reply
  • Tom Hendrick
    on May 09 2012 15:57 PM
    Guru86375 points
    Yes - I believe you've got it!  I think you may have forgotten to subtract the 4*tCLK though; the MIN SCLK speed is just over 7MHz to get all data at 32000sps.
    Tom
    Report Abuse
    • Reply
  • Esteban Valverde
    on May 10 2012 08:12 AM
    Prodigy40 points
    Yes, Tom, I think I got it! Thanks at all. If you don't mind I'll appreciate to continuing asking to you about ADS1298 on this topic.
    best regards, Esteban
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
