• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » Negative pins condition when using the built-in function of augmented leads deriving in ADS1298
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 7 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 15 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 27 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is answered
Alexander Uvarov
Posted by Alexander Uvarov
on May 14 2012 03:50 AM
Prodigy240 points
Hello!
When using the built-in function of augmented leads deriving, the appropriate signal combinations are used for driving the negative lines of chanels 5,6 and 4 or 7. And there is no information in the datasheet about how the input pins of these lines should be connected. Does anybody know it? Should I keep these pins (IN4N, IN5N, IN6N, IN7N) not connected or grounded or in some another condition?
Regards, Alex.
ads1298 goldberger central terminal augmented leads negative line negative pin
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tom Hendrick
    Posted by Tom Hendrick
    on May 14 2012 19:16 PM
    Guru86200 points
    Hello Alexander,
    If you look through the schematic in the back of the ADS1298ECG-FE Users Guide, and consider the jumper defaults of the board, you will see that the IN(-) terminals are connected back through the WCT output of the ADS1298.  This connection is also noted in the ADS1298 data sheet on page 55 in the description of the WCT1 register.
    Tom
    Report Abuse
    • Reply
  • Alexander Uvarov
    on May 14 2012 22:52 PM
    Prodigy240 points
    Hello, Tom!
    I already know it. Maybe my explanation is not clear. The idea is I want to use channels 5,6,7 as augmented leads. In this case I need to set the bits 5,6,7 (aVR_CH7, aVL_CH5, aVF_CH6) of register WCT1 to the "1". Thus, an appropriate reference signals will be routed to the corresponding negative lines (IN5N, IN6N, IN7N) inside of the IC, so that I don't need to drive the IN5N, IN6N and IN7N pins with any reference signals. But what should I do with these not connected pins? Keep not connected or connect to the ground or use some another way?
    Regards, Alex.
    Report Abuse
    • Reply
  • Tony Calabria
    Posted by Tony Calabria
    on May 15 2012 10:45 AM
    Mastermind42750 points
    Hi Alex,
    For the augmented lead channels, leave the negative (-) pins floating to avoid any summing problems. Use weak pull up resistors connected to AVDD for any unused analog input pins that are not used.
    Tony
    Report Abuse
    • Reply
  • Alexander Uvarov
    on May 16 2012 03:32 AM
    Prodigy240 points
    Hi Tony!
    Thanks for your advice! But according to the figure 56 of the datasheet it would cause the summing of reference signal with AVDD. Am I right?
    Alex.
    Report Abuse
    • Reply
  • Tony Calabria
    on May 16 2012 11:25 AM
    Verified Answer
    Verified by Alexander Uvarov
    Hi Alex,
    You are correct. I apologize. You will want to keep those inputs floating when using augmented leads. That is how we set the inputs during the parts characterization when we tested the augmented lead functionality. I will go in and edit the other post so future users understand the correct setup.
    Tony Calabria
    Report Abuse
    • Reply
  • Alexander Uvarov
    on May 17 2012 02:56 AM
    Prodigy240 points
    Thank you, Tony!
    I'm glad that this post could be useful for other users.
    And if you say these pins could be kept floating, then I assume that nothing special is placed at the input circuits of ADS1298. Thus the grounding of pins IN4N, IN5N, IN6N, IN7N is also correct.
    Regards, Alex.
    Report Abuse
    • Reply
  • Tony Calabria
    on May 17 2012 08:34 AM
    Verified Answer
    Hi Alex,
    I am not sure I understand you last comment. Pins IN5N, IN6N, and IN7N are the three used for the augmented leads in which an internal connection will be made from the appropriate WCT amplifiers to the input. Those three input pins must be left floating and not grounded.
    Tony
    Report Abuse
    • Reply
  • Alexander Uvarov
    on May 17 2012 23:00 PM
    Prodigy240 points
    Thanks a lot, Tony!
    Now I have the comprehensive notion about this subject.
    Alex.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
