• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS8329 noise using internal clock
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 2 days ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 10 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 17 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
  • Craig Hillis
    Posted by Craig Hillis
    on Jun 01 2012 07:56 AM
    Intellectual300 points
    The noise is a broad hump (5kHz – 10kHz wide) that is 6dB to 10dB above the noise floor. Its frequency changes with sample rate and sometimes over time. I have changed the analog power supply, reference and input and it remains. I cannot see it on the reference, power supply or inputs in-band with an audio spectrum analyzer (it may be high frequency aliasing down). I have put an anti-alias filter at 40kHz on the input and it is still there. I have the board in a shielded box and have turned off the Wi-Fi and other RF transmitters in the building with no luck.
    We are using the internal clock for sampling, and manual trigger mode. We are not reading in the quiet time.
    Using the EOC/INT/CDI pin as EOC, active low output, there is approximately 20ns of jitter on the rising edge of the EOC line relative to the start of conversion. The EOC line is low for what should be 18 CCLKs based on the data sheet numbers, but the duration has the 20ns of jitter. This leads me to think the internal clock has jitter and could be causing the noise.
    I am wondering if the jitter is normal. Also, could the internal clock be beating with the SPI clock and data and causing noise internal to the device? At most sample rates we are not reading during the concersion, so I do not think beating is the issue.
    ADS8329
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Tom Hendrick
    Posted by Tom Hendrick
    on Jun 04 2012 10:21 AM
    Guru86210 points
    Hi Craig,
    Welcome to our forum!  I don't recall seeing this behavior in the ADS8329.  Can you let us know how you have the configuration register (CFR) set and possibly share a snippet of your schematic with us?  We can try to repeat your tests here.  What reference are you using?
    Tom
    Report Abuse
    • Reply
  • Craig Hillis
    on Jun 04 2012 11:20 AM
    4024.ADS8329.pdf
    Tom,
    Attached is a copy of the schematic for the ADS8329 section. There is an error on the schematic showing a 27pF capacitor on the 1.8V power line, it has been replaced with a 4.7uF capacitor.
    The analog switches for the filter and the gain at the input buffer (U156, U159, U60) have been removed. R376 has been populated with a 0 ohm resistor, and R53 removed (U155A is a unity gain buffer with a first order anti-alias RC filter on its input).
    So to simplify, the signal is connected from C211 (AC_IN) to R316 (HSIN) and the output of U155A is connected to R143 (HS_ADC_IN). The input side of C211 (IN) is shorted to analog ground.
    The reference is MAX6145.
    Register Value
    Setting
    Description
    CFR
    0x73D
    CFR.D11
    0b
    Manual channel selection mode
    CFR.D10
    1b
    Internal conversion clock used
    CFR.D9
    1b
    Manual trigger manually started by falling edge of CONVST
    CFR.D7
    1b
    EOC active high / INT active low
    CFR.D6
    1b
    Pin 10 used as EOC
    CFR.D5
    1b
    Pin 10 used as EOC/INT output
    CFR.D4
    1b
    Auto nap power-down disabled
    CFR.D3
    1b
    Remove device from nap power-down (resume)
    CFR.D2
    1b
    Remove device from deep power-down (resume)
    CFR.D1
    0b
    TAG bit disabled
    CFR.D0
    1b
    Normal operation
    Report Abuse
    • Reply
  • Craig Hillis
    on Jun 04 2012 12:06 PM
    The data sheet shows a 470pF capacitor between pins 3 and 4. The pole formed with the 20ohm resistors is well out of band. Is there any drawback to increasing the capacitor value? I notice the noise floor drops with a larger (10nF) capacitor.
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 06 2012 14:08 PM
    Guru86210 points
    Hi Graig,
    Has this issue been resolved?  I know you were working off-line a bit with Ryan with this issue but I've not heard anything from him lately.
    Tom
    Report Abuse
    • Reply
  • Craig Hillis
    on Aug 08 2012 10:53 AM
    I still have not found a solution or cause. I am looking at sending a blank board so the factory guys can try to replicate the problem.
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 14 2012 16:44 PM
    Guru86210 points
    Great!  Work through Ryan and we'll see what we can do on our end.
    Tom
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
