• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » F28335 with ADS8556
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 2 days ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 8 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 16 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
F28335 with ADS8556
F28335 with ADS8556
This question is answered
Yash Bhagwat
Posted by Yash Bhagwat
on Jun 15 2012 19:10 PM
Prodigy40 points
I am using F28335 and need to interface upto 24 external ADC channels from ADS8556 with the MCU ( these are additional channels beyond the inbuilt ADC). What is the best way to interface - SPI / McBSP?
Also, will I need to use an external channel multiplexer if using McBSP ?
28335 controlcard 16bits/8Canel ADC
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • BrandonAzbell
    Posted by BrandonAzbell
    on Jun 15 2012 21:39 PM
    Guru55185 points
    A possibility might be to use the parallel interface mode.  The TMS320F28335 supports an external memory interface called the XINTF.  You need to have some logic to expand the addresses with the 3 chip selects available on the interface.
    Brandon
    Report Abuse
    • Reply
  • Yash Bhagwat
    on Jun 18 2012 11:38 AM
    Prodigy40 points
    Actually I plan to have following interfaces on F28335 -
    1. 16 channels using in-built ADCs
    2. 24 external ADC channels
    3. MCU - FPGA via EMIF/XINT
    4. External SDRAM via EMIF/XINT
    Given these interfaces, I think I will have to share the XINT address space for external RAM and FPGA connections; can ADC channels still be shared on same XINT ?
    In this scenario, will McBSP be a better option ... want your suggestions on these interfaces
    Report Abuse
    • Reply
  • Tom Hendrick
    Posted by Tom Hendrick
    on Jun 18 2012 14:03 PM
    Guru86375 points
    Hi Yash,
    I don't see any reason why keeping the ADS8556 on the EMIF would be an issue.  You'd have to address decode the /CS input (using something like an SN74HC138) and you could potentially use the SOC from the F28335 to trigger the CONVST inputs.  I believe the McBSP is in the low-speed clock domain which might be problematic in your control loop if you used the serial mode of the ADS8556.
    Tom
    Report Abuse
    • Reply
  • Yash Bhagwat
    on Jun 26 2012 10:44 AM
    Prodigy40 points
    Hi Tom,
    Thank you for your reply. I tried looking up some documentation and example code like adc_on_xintf and xintf_run_from. I'm not sure if I can use ADC channels, FPGA connection and SARAM simultaneously using same XINTF. Given a single data bus XD [31:0], even if I allocate something like ADC on Zone 0, FPGA on Zone 6 and may be SARAM on Zone 7 (separately addressed), can all interfaces work in parallel ?
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 06 2012 14:38 PM
    Guru86375 points
    Hi Yash,
    How is your project going?
    Tom
    Report Abuse
    • Reply
  • Yash Bhagwat
    on Aug 06 2012 15:32 PM
    Verified Answer
    Verified by Tom Hendrick
    Prodigy40 points
    Hi Tom,
    I'm working on the memory interface part of the project (FPGA-DSP via XINT, working on eZdsp). The issue of ADC channels has been solved. However, I'm looking into the analog pre-processing of the ADC inputs, especially for the inbuilt channels on F28335, by using something like INA 159. Can you suggest any reference designs for the same ?
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 06 2012 15:41 PM
    Guru86375 points
    Hi Yash!
    I am glad to hear you are making progress!  I've not worked much with the ADC's inside the F28335.  You might try cruising around in the C2000 forum to see if there are any references there.
    Tom
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
