• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » 24-bit ADC design for Strain gage measurement
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 4 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 11 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 24 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is answered
Gamin Inganela
Posted by Gamin Inganela
on Jun 25 2012 10:24 AM
Intellectual315 points
Hello all,
I am writing to request a recommendation for our situation (which I believe is a fairly generic one): We are making measurements using a strain gage, with the parameters as follows:
Excitation voltage = 5 V; Sensitivity = 5 mV / V; Desired sample rate for measurement = 1 kHz or greater; Desired ADC resolution = 18 bits or greater
Can you propose a design that would allow us to make such a measurement with our strain gages? We would appreciate either a generic schematic (or app-note), or else a recommendation in terms of specific parts. I presume this would involve an ADC such as the ADS1252, in addition to an opamp and a high-precision voltage reference.
The reason we are searching for a TI-verified design is because we would like to expedite our prototype-and-production time for this particular measurement; We have looked through the application notes of some ADCs and haven't yet found a close enough match to our particular situation, hence I am bringing this question up here.
Thank you!
Cheers,
Gamin
adc ADS1252 24-bit sigma delta ADC
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Bob Benjamin
    Posted by Bob Benjamin
    on Jun 25 2012 16:35 PM
    Verified Answer
    Verified by Tom Hendrick
    Mastermind33935 points
    Gamin,
    Here is a web page with bridge sensor information and design considerations.
    http://www.ti.com/ww/en/industrial/sensors/weigh/learn.html
    The specific information revolves around the ADS123x family of parts, but they do not meet the 1ksps requirement.  The ADS1252 is a good part, but you will need some external gain as there is not a PGA associated with this part.  You might consider the ADS1255, which has a PGA with a gain up to 64.
    The ADS1259 is a very low noise delta-sigma that also requires some gain stage at the front end.  You could consider using the OPA333 as the amplifier between the strain gauge and the ADC.  There are numerous other op amps that could be considered as well.
    Bob B
    Report Abuse
    • Reply
  • Gamin Inganela
    on Jun 25 2012 23:07 PM
    Dear Bob,
    Appreciate the pointers. I have one other question...
    First, thank you for the three part recommendations. I intend to use the ADS1252 along with an OPA333 for pre-amplification.
    Secondly, we do have an alternate application for which the slower-sampling but PGA-integrated ADS123x family seems to be appropriate (especially given that much app-note information is available for this part).
    Can you provide (or refer me to a link for) existent example microcontroller pseudocode/source-code/firmware for interfacing with the ADS123x family, or for any ADC with an equivalently simple data interface ?
    Thank you,
    Gamin
    ADS1232 ADS1252 ADS123x
    Report Abuse
    • Reply
  • Murali Srinivasa
    Posted by Murali Srinivasa
    on Jun 25 2012 23:45 PM
    Intellectual1040 points
    Hi Gamin,
    TI has a new family of products called SensorAFE's. It provides a easy to use development platform along with the MCU code library,You can take a look at LMP90100 family of products here:http://www.ti.com/product/lmp90100#parametric , It has max data rate of 214 Sps.
    There is a code library for interfacing LMP90100 devices with any MSP430 family devices,which can be found here :
    1. App Note,http://www.ti.com/lit/an/snaa134/snaa134.pdf
    2. Code, http://www.ti.com/litv/zip/snac029
    Murali
    LMP90100 code library
    Report Abuse
    • Reply
  • Bob Benjamin
    on Jun 26 2012 14:52 PM
    Gamin,
    We have a load cell reference design using the ADS1232 called the ADS1232REF.  This board is controlled by a MSP430F449, which has a built in LCD controller.  All files and code pertaining to this board can be found and downloaded from:
    ftp://ftp.ti.com/pub/data_acquisition/ADS123xREF/ADS123x_CDROM/
    All digital control (Speed, Mux, etc.) in this design is GPIO from the micro.  This is not necessary unless this specific control is needed.  The pins can be tied high or low appropriately.  The SPI interface uses the built in hardware peripheral of the micro.  The code example is built with GCC along with freeRTOS code.  This can sometimes be difficult to follow, but the primary initialization and communication to the ADS1232 is in the 'c' file 'ads1232.c.'
    Bob B
    ADS1232
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
