• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » Interfacing of ADS1278 with FPGA
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 1 day ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 9 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 16 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
  • Mahesh Hegde
    Posted by Mahesh Hegde
    on Jul 12 2012 05:10 AM
    Prodigy190 points
    I am working on ADS1278 which is having 8 analog and digital channels. Schematic setup is explained below.
    Schematic Setup :
    I have connected SYNC, FSYNC , SCLK, CLKDIV, DOUT1 signals. I want to operate the 1278 IC in Low speed mode and CLKDIV made as 1(High) also mode pins set to  "11" . FORMAT(2:0) pins are set to "100".  So i have set Frame_Sync Format. I have given 27MHz crystal clock to the ADC.
    Software(Programming in FPGA): All the below operation is happening on falling edge of the 27Mhz clock.
    By default SYNC is high, then it made it as low for one clock cycle (It will go for high '1' after 1 clock cycle). FSYNC is generated continuously for 128 conversion cycles.
    After that i generated FSYNC (Made high for one clock cycle and made low). Data is collected for next 24 clock cycles then waited for 2535 clock cycles. Again process(FSYNC generation and data collecting) is continuously running. I have seen varying analog input. But digital output i am not able to see on the scope (at DOUT).
    Can you please take me forward?
    ads1278 fpga
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Tony Calabria
    Posted by Tony Calabria
    on Jul 13 2012 10:15 AM
    Mastermind42750 points
    Hi Mahesh,
    Could you send a scope picture showing your Frame Sync line, SCLK, data, etc. I would recommend getting your hands on an EVM so you can look at the timing of our communication. The EVM-PDK evaluation software uses the Frame Sync protocol so you can look at it on a scope to hopefully help debug.
    Tony Calabria
    Report Abuse
    • Reply
  • Mahesh Hegde
    on Jul 14 2012 01:38 AM
    Prodigy190 points
    Dear Tony,
    1278 is not responding in my design. I have changed Frame_Sync format to SPI format, just to  check DRDY on the DRDY/FSYNC pin. But DRDY is continuously high. It's not pulsing only. I have kept SCLK to '0'. I kept high on PWRDN1 and PWRDN2 pins as well. I am not able to understand why ADC is not giving the DRDY?
    Report Abuse
    • Reply
  • Tony Calabria
    on Jul 15 2012 21:09 PM
    Hi Mahesh,
    If placed in SPI mode, you should see the /DRDY line idle high and pulse low at the data rate frequency. If you are not seeing these /DRDY pulses, which are approximately 4 tclks (master clock periods), then the device is either in a power down state or it is not getting a master clock. Double check that the ADC is being fed a master clock user for all the ADC internal timings and conversions. If the master clock is there, double check that, at least, one of the power down pins is held high so the device is not put to sleep. If that is correct, double check the supply pins to make sure the device is properly powered. When configured correctly, you should, at the very least, be able to see the /DRDY pin toggling.  If connected to the FPGA, make sure that the I/O pin is set to an input so that the FPGA is not driving the /DRDY line high or low as the converter tries to toggle it.
    Tony Calabria
    Report Abuse
    • Reply
  • Mahesh Hegde
    on Jul 15 2012 22:25 PM
    Prodigy190 points
    Dear Tony,
    Master clock is going to ADC & CH1, CH2 channels (PWRDN1, PWRDN2) are held high. All the mentioned voltages are given to the respective power pins (5v, 3.3v, 1.8v) and  DRDY pin made as input to FPGA. But DRDY is continuously high only. I don't know the reason. I have done one mistake. That i explained below.
    When changing Frame_Sync mode to SPI mode i have done one mistake. In Frame_Sync mode DRDY/FSYNC made as output i.e FPGA wa driving the FSYNC. When i changed to SPI mode both are happening(FPGA was driving FSYNC and ADC also try to drive the DRDY line) for some time(2 - 3 min).  Then i configured DRDY as input. Do you think is it problem for ADC?
    Report Abuse
    • Reply
  • Mahesh Hegde
    on Jul 18 2012 05:13 AM
    Prodigy190 points
    ads_1278.avi
    Dear Tony,
    I glad to inform that "i am able to get DRDY from ADC." But i didn't got idea how the DRDY will work? I have attached the video clip of DRDY, SCLK here. DRDY status is changing continuously in each conversion. I am reading 1st channel at DOUT1. I have planned to read the all the channel data on DOUT1 itself. Please see the attached video clip and please give me an idea on DRDY.
    Report Abuse
    • Reply
  • Tony Calabria
    on Jul 18 2012 12:45 PM
    Hi Mahesh,
    /DRDY is used for SPI rather than /FSYNC. I assume you have switched to using SPI now.
    /DRDY is an interrupt used to alert the user when new data is ready. A falling edge of /DRDY lets the user know when data is ready. The line will then return high when it sees the first SCLK pulse. If no SCLKs are sent, the /DRDY will remain low until new data is ready, in which it will return high and immediately low. Basically, the line will appear to idle low and pulse high when no SCLKs are sent. I would recommend re-reading the data sheet now if you are now using the SPI communication mode.
    Tony Calabria
    Report Abuse
    • Reply
  • Mahesh Hegde
    on Jul 18 2012 23:30 PM
    Prodigy190 points
    Dear Tony,
    Thanks for your valuable reply. After your reply i have gone through the datasheet again and I have observed the changing in DRDY without SCLK and with SCLK. I have seen one channel data (CH1 channel data) on DOUT1 pin.
    If i want to read all the channel data i should generate 24 * 8 (SCLK) pulses (24 SCLK for each channel, so total 192 SCLK pulses required to read off all the channel data) and i should read the status of the DOUT1 pin on each rising edge of the SCLK.
    This is my understanding after reading datasheet. Please correct me, if my understanding is wrong.
    Mahesh Hegde
    Report Abuse
    • Reply
  • Tony Calabria
    on Jul 19 2012 10:10 AM
    Mahesh,
    You are correct. Double check your format pins with page 30 of the data sheet to make sure you are in TDM mode with the SPI interface to have all the output data come out of DOUT1.
    Tony Calabria
    Report Abuse
    • Reply
  • Mahesh Hegde
    on Jul 21 2012 02:09 AM
    Prodigy190 points
    Dear Tony,
    I have read the serial data from ADC and done serial to parallel data using shift register in FPGA. I have detected DRDY then  i have generated SCLK (24 clk pulses to read 24 bit of data) to read the data from ADC. The clock frequency same as Master Clock. Master clock i have used is 27 Mhz. So the SCLK switching frequency also same (27 Mhz for 24 clock). With this case read data is not proper.
    When i reduce the master clock to 6.75 MHz read data is proper (SLCK switching frequency also 6.75MHz).I am getting 2.5 KHz  data rate with this case.I don't know where the data problem lies.
    Can you please help me to increase the data rate?
    Report Abuse
    • Reply
  • Tony Calabria
    on Jul 23 2012 09:46 AM
    Hi Mahesh,
    Double check your timing specs. A lot of time the tMSBPD timing spec is overlooked causing you to miss the MSB offsetting the entire data word. Another place to look is at the SCLK phasing and polarity. What edge are you using to latch data and to change data? If this is incorrect, there could be a chance that the data is read properly at slower speeds and read back as incorrect when run faster. Slowing the master clock down is going to slow the requirements for a lot of the internal timings so, best place to look is the timing diagrams relating SCLK to the master clock to try and see what is not being met. I would look at your SPI transfer word on an oscilloscope to try and see if something may be wrong. If you post a picture of your o-scope data word and SCLK, I would be happy to look.
    Tony Calabria
    Report Abuse
    • Reply
  • Mahesh Hegde
    on Jul 23 2012 23:10 PM
    Prodigy190 points
    Videos.rar
    Dear Tony,
    Here i am attaching 3 videos. They are
    1)Wavefroms                    --   DRDY with SCLK is shown & Data with SCLK is shown. I am reading 4 channels continuously on DOUT1. But only one analog input is connected to CH1 and rest of the analog pins of ADC is kept open.
    2)Data_at_6_5Mhz_clk   --  Continuous read data is shown in the video while varying the analog voltage across the ADC. Master clock provided here is 6.5Mhz.
    3)Data_at_27Mhz_clk     --   Continuous read data is shown in the video while varying the analog voltage across the ADC. Master clock provided here is 27Mhz.
    Mahesh Hegde.
    Report Abuse
    • Reply
  • Tony Calabria
    on Jul 31 2012 11:56 AM
    Hi Mahesh,
    I have looked through the videos and see that there is a fair amount of noise on the SPI lines? Is that truly there, or are you not grounding the oscilloscope probe properly. If it really is that noisy, you may want to include series 33 ohm resistors on the SPI lines to try and clean in up. If they are that noisy, that could lead to inaccurate readings on the communication side of things. My recommendation for testing is to put full scale on the input channel during testing. This would allow you to track what you are reading back relative to full scale when sweeping the master clock to help you get an idea of how your data is incorrect. It is hard for me to understand by what factor your data is off when I do not know your input signal amplitude. keep the input constant at either +Vref or -Vref. I would actually recommend railing the input by Vref + 100mV to insure that your 'correct' output reading is always reading 0x7FFFFF.
    Tony Calabria
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
