• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » DSK loop.
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 1 day ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 9 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 17 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
DSK loop.
DSK loop.
This question is answered
Umar Khan
Posted by Umar Khan
on Aug 02 2012 06:35 AM
Intellectual320 points
     I am trying to develop a simple loop using the ADS 8361 , C6713 DSK (with 5-6k interface) and the DAC 8831. All I want to do now is to read data in using the ADS and pass it out using the DAC. Once this runs properly I intend to put in code for a PID controller. To make this loop I have used the code from  SLAA 164,  and SLAA246 and a few suggestions in a previous e2e ti post.
http://e2e.ti.com/support/data_converters/precision_data_converters/f/73/p/2858/9827.aspx#9827
 I read the data in using McBsp0 and write it out using McBsp1. The lines of code that write to McBsp 1 (highlighted in code below) sit in the ISR for the McBsp0 receive interrupt. I took the configurations for McBsp0 and 1 from the SLAA 164  and SLAA 246 respectively.
The problem is that when I pass in a signal (in this case a 1 Hz sinusoid) the output is the same except its jumping between two values, as shown in figure below. This was recorded using a National Instruments DAQ USB 6356 at 100,000 samples per second.
I have copied my code  below. Can you please provide me any suggestions or clues about what I am doing wrong here.
/* FILENAME: main.c */
/* DESCRIPTION: This program uses McBSP0 to read 1024 */
/* samples continuously from the ADS8361 16-bit 500KSPS */
/* Analog-to-Digital Converter. The samples are stored in */
/* the buffer called ad_buffer. */
/* AUTHOR : DAP Application Group, T. Hendrick, Dallas */
/* CREATED 2002(C) BY TEXAS INSTRUMENTS INCORPORATED. */
/* VERSION: 1.0 */
#include "led_Mcbsp0cfg.h"
/* Header file */
#include "csl.h"
#include "csl_irq.h"
#include "csl_mcbsp.h"
#include "dsk6713.h"
/*Declarations*/
#define BLOCK_SZ 1 /* size of data buffer */
/*DSP/BIOS variables*/
extern far MCBSP_Handle hMcbsp0;
extern far MCBSP_Handle hMcbsp1;
/*Global variables*/
unsigned int ad_buffer[BLOCK_SZ];
unsigned short ad_buffer_A[BLOCK_SZ], ad_buffer_B[BLOCK_SZ], i=0, j=0,x=0;
unsigned volatile int ad_temp;
* Function: main()
* Description: Enables McBSP1 receive interrupt and McBSP1
void main() {
DSK6713_init();
DSK6713_rset(DSK6713_MISC, 0x03); //NOTE - McBSP 2 is on HPI Conn!
IRQ_enable(IRQ_EVT_RINT0);
MCBSP_start(hMcbsp0, MCBSP_RCV_START | MCBSP_SRGR_START| MCBSP_SRGR_FRAMESYNC, 0);
MCBSP_start(hMcbsp1, MCBSP_XMIT_START | MCBSP_SRGR_START| MCBSP_SRGR_FRAMESYNC, 0);
* Function: McBSP1Rcv_ISR()
* Description: McBSP0 Receive Interrupt Service Routine. Reads sample out of
* receive register and stores it in array call ad_buffer. When the buffer
* table is full, it resets the pointer to the beginning and flushing receive
* buffers.
void McBSP0Rcv_ISR(void)
/* Wait until a value is received then read it */
while (!MCBSP_rrdy(hMcbsp0));
ad_temp = MCBSP_read(hMcbsp0) >>2;
if( (ad_temp & 0x00010000) == 0x00010000 )
ad_buffer_A[i] = (short)(ad_temp & 0xFFFF);
// WRITE DATA TO MCBSP 1
while (!MCBSP_xrdy(hMcbsp1));
MCBSP_write(hMcbsp1, ad_buffer_A[i]);
i++;
else
ad_buffer_B [i] = (short)(ad_temp & 0xFFFF);
if (i >= BLOCK_SZ ) /* Reset index? */
i=0;
MCBSP_read(hMcbsp0); /* Flush receive register */
* End of main.c
ADS 8361 DAC 8831
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tom Hendrick
    Posted by Tom Hendrick
    on Aug 02 2012 10:18 AM
    Guru86210 points
    Hi Umar,
    There may be something in the setup of the McBSP to the DAC8831 and/or the ADS8361.  In CCS, there is an option to 'View Memory', you can also open a graph window to display the contents of ad_buffer_A.  Can you please verify that the data received by the McBSP0 is actually correct?
    Tom
    Report Abuse
    • Reply
  • Umar Khan
    Posted by Umar Khan
    on Aug 02 2012 12:43 PM
    Hi Tom,
                    Yes I think the data is being read correctly into ad_buffer_A. To verify this I increased the buffer size BLOCK_SZ  to 1000 so that I can see a waveform. Since I am running the ADS 8361 in mode II , the sample rate is 250 kSPS. So a buffer size of 1000 implies that I collect data for 1000 x (1/250000) = 4ms. I then passed in a 1000 Hz sine and as expected got the 4 cycles. I have pasted the screen shot below,
    I guess the sharp jump after cycle three occurs because I stop the code execution while the buffer is being filled.
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 03 2012 12:45 PM
    Guru86210 points
    Hi Umar,
    The DAC output carries the sine wave envelope, so I suspect the issue may be in your code translation.  The data from the ADS8361 is in binary twos compliment format, while the DAC8831 expects to see straight binary data.  Try X'oring your ad_buffer_a with 0x8000.
    Tom
    Report Abuse
    • Reply
  • Umar Khan
    Posted by Umar Khan
    on Aug 08 2012 14:54 PM
    Hi Tom,
                     I tried the XOR method however it didn't work either. So I tried many other things just to see if the problem might be somewhere else and what I found was that if I take my original code (the one I pasted previously) and do the following changes it either works or fails completely. When it fails the output is a flat DC. Here are the changes I made,
     Changed McBSP 0  frame period to 19 and frame width to 18
       and          McBSP 1  frame period to 17
    So what I guess is that the problem is with the McBSP settings. In addition I have noticed that when I try to view the contents of ad_buffer_A I get completely invalid data. But any way as long as it outputs the data correctly I guess it is doing some thing right.
    Can you please provide me some suggestions regarding how I can make it work all the time. I have copied a screen shot of the input to ADS8361 (1000 Hz sine) and the corresponding DAC8831 output.
                                    Umar Khan.
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 08 2012 17:55 PM
    Guru86210 points
    Can you post your project (zip up the folder and attach)?  I'll take a look at it.
    Tom
    Report Abuse
    • Reply
  • Umar Khan
    Posted by Umar Khan
    on Aug 09 2012 08:57 AM
    Hi Tom,
                   Please find my project folder attached. Many thanks for your help.
    7140.dskLoop.rar
                              Umar Khan
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 11 2012 16:04 PM
    Guru86210 points
    Hi Umar,
    Sorry for the delay here - I was at NI Week 2012 the past few days (very cool, by the way) and am now back in Dallas.  I'll take a look at your code over the weekend and see if we can't get this resolved by Monday.
    Tom
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 14 2012 13:24 PM
    Guru86210 points
    Hi again Umar,
    Are you using our DAC8831EVM for this loop?  If so, let me know how you have SW1 set (towards BIP or UNI?).  I added a little routine to your project to output a sine wave directly to the dac without going through the ADS8361 and it seems to be working just fine without any modifications to the McBSP settings.
    Tom
    Report Abuse
    • Reply
  • Umar Khan
    Posted by Umar Khan
    on Aug 15 2012 11:25 AM
    Hi Tom,
                  Yes I am using the DAC8831 EVM with the SW1 switch towards BIP, since I eventually need a bipolar output.
    Umar.
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 15 2012 14:04 PM
    Guru86210 points
    dskLoop.zip
    OK - that should work.  Try the attached project and let me know what happens.
    Tom
    Report Abuse
    • Reply
  • Umar Khan
    Posted by Umar Khan
    on Aug 16 2012 12:50 PM
    Hi Tom,
                    I tried the code you sent (main2 with the modified cdb ) but did not get the expected sine. Also the problem that the code dosen't work all the time is still there.  I then tried the following,
    Tried to output the cosine table
    Replaced  the index variable i in the line that writes data to McBSP with a constant to see if a DC is given out
    Replaced the loop before McBSP initialization with a nested loop to increase the delay before McBSP is initialized
    Tried all these things and the original code you sent on a Win XP PC. Uptill now I have been using a Win 7 PC with XP Mode. I suspected that the XP mode was the problem .
    In all these cases I got the same result, i.e either a very noisy output or a DC. I used view graph option to see the contents of sine and cosine arrays, they look ok (pasted below).
    The next figure shows the input to the ADC and the output from DAC. I passed in a 1000 Hz sine just to see if I can display it using view graph for ad_buffer_A but that data was clearly incorrect.
    The output from the DAC should have been the sine as stored in sine table.
    Umar.
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 19 2012 10:59 AM
    Guru86210 points
    Hi Umar,
    What happens if you use main.c and not Main2, I modified the cdb but I also changed the way you are masking and shifting the data.  That is the code that worked for me...
    Tom
    Report Abuse
    • Reply
  • Umar Khan
    Posted by Umar Khan
    on Aug 22 2012 06:01 AM
    Verified Answer
    Verified by Tom Hendrick
    Hi Tom,
                     Sorry for the delay. I tried your code,  main.c with both modifiedCDB and the orignal CDB files but the output just continued to be a flat DC. I tried changing the  highlighted line below so that  ad_buffer_B is written instead of ad_buffer_A but that didn't help either,
    if( (ad_temp & 0x00020000) == 0x00020000 )
    ad_buffer_B[i] = (short)(ad_temp & 0x0000FFFF);
    //My PID will be here
    MCBSP_write(hMcbsp1, ad_buffer_A[i]^0x8000);
    i++;
    However I kept trying lots of other things untill finally this one worked. I took my orignal dskLoop code and set the
    Sample rate generator for ADC to Frame Period =20, Frame Width=19, Clock freq Divider =12,
    Sample rate generator for DAC to Frame Period =17, Frame Width=1, Clock freq Divider =15,
    XORed ad_buffer_A with 0x8000
    I have now connected the analog input of the ADC as single ended source with 2.5V ref taken from the EVM. The input now varies from 0-5 and the DAC output from -2.5 to 2.5. It has worked every time so far and hope it continues to do so.
    So I guess I can move on to implementing my PID controller and the new set of stuff like modifying the dap signal conditioning boards for matching my I/O voltage ranges and filtering requirements :)
    Many thanks for you help Tom, your suggestions were really helpful.
    Umar Khan.
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 22 2012 09:35 AM
    Guru86210 points
    Hi Umar,
    That's great news!  I'm happy to hear that you're up and running finally!
    Tom
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
