• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS1298 on TMS320C5515 with ECG project
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 7 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 14 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 27 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is answered
Yuan-Heng Lu
Posted by Yuan-Heng Lu
on Aug 08 2012 02:57 AM
Prodigy160 points
This project need 10 inputs , but I want just two channels .
Is it possible?
I just want RA and LA two channels .
And the others are connected ground with TP8 on ADS1298.
How to redesign my project or my ADS1298 circuit ?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • HECTOR
    Posted by HECTOR
    on Aug 08 2012 03:01 AM
    Intellectual585 points
    If you need only two channels why dont you use ADS1292? cheaper ..
    Report Abuse
    • Reply
  • Yuan-Heng Lu
    on Aug 08 2012 03:03 AM
    Prodigy160 points
    Because I need other inputs but not ECG signal.
    Report Abuse
    • Reply
  • Tom Hendrick
    Posted by Tom Hendrick
    on Aug 08 2012 06:15 AM
    Guru86200 points
    Hi Lu,
    What sort of 'other inputs' do you need?  Are you looking for digital I/O or are you looking to digitize analog signals of some sort?  If analog, what is the nature of the signal (bandwidth, magnitude, etc)?
    Tom
    Report Abuse
    • Reply
  • Yuan-Heng Lu
    on Aug 08 2012 19:49 PM
    Prodigy160 points
    Yes, the other signal bandwidth :0Hz~150Hz  , mv level.
    I want to digitize analog signals .
    So, could  you reply my other question?
     If I want two inputs :RA&LA, other signals are connected ground on ADS1298.
    Will this action be OK ?
    Report Abuse
    • Reply
  • Tony Calabria
    Posted by Tony Calabria
    on Aug 09 2012 09:41 AM
    Mastermind42750 points
    Hi Lu,
    An ECG lead is a differential measurement. Lead I would a differential measurement across RA and LA. If you need to use single ended measurements on the other channels, you can do Lead I on channel 1 and the tie the (-) pins of channels 2 - 7 to ground and the (+) pin of those channels for single ended measurements for whatever else you need to measure.
    Tony
    Report Abuse
    • Reply
  • Yuan-Heng Lu
    on Aug 09 2012 20:00 PM
    Prodigy160 points
    Thanks for Tom's reply.
    Second,I find out that the noise will be higher if just no RL signal.
    Do the question have a solution?
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 12 2012 08:19 AM
    Guru86200 points
    Hi Lu,
    You can use the remaining channels of the ADS1298 as a general purpose ADC to digitize analog signals - they do not have to be 'ECG' signals.  The inputs to the ADS1298 are differential so your analog signal could be applied to the INx(+) pins, with the INx(-) grounded or tied to AVdd/2.
    Tom
    Report Abuse
    • Reply
  • Yuan-Heng Lu
    on Aug 12 2012 19:53 PM
    Prodigy160 points
    I know that ADS1298 is differential input,but RL is not a input.
    It's a right leg drive circuit.
    But I don't want the RL input .
    Just RA and LA.
    lead I is LA minus RA.
    without RL electrode, the signal's noise is higher.
    Your reply is that modify a single input .Right?
    Report Abuse
    • Reply
  • Tony Calabria
    on Aug 13 2012 10:11 AM
    Verified Answer
    Verified by Tom Hendrick
    Hi Yuan-Heng,
    The RLD primary function is to set the operating point for the body. If you decide to not use the RLD, you will need to bias the inputs to the ADC using other means. This could be done by AC coupling the inputs and using weak pull up/down resistors to the ADC power supplies. Search around the forum and you will find others who are doing single lead ECG with no RLD electrode.
    Tony Calabria
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
