• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » Ads1298 sampling problems
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 12 hours ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 8 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 15 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
  • Alberto Tablon
    Posted by Alberto Tablon
    on Aug 11 2012 18:39 PM
    Prodigy60 points
    I'm working with the ads1298 wich is connected with a HC08 family micro via SPI at a speed of 1MHZ. I'm testing my system with a signals generator that puts in the channel1, in a single ended configuration( in1+=generator in-=DGND), a sin waveform of 10Hz and Vmax=1.5V y Vmin=0V. After I've got the samples in the micro i transmit them to the computer via SCI. Then I grafic all with matlab.  The Ads1298 is working with internal reference of +4V with AVDD=+2.5V and AVSS=-2.5V. Also i'm using the internal clock. I configure the AD to have only the channel1 power up and to sample at 500sps. My problem is the following.
    When I try my system with this kind of waveforms appear lots of glitches. I'dont have any idea of what could be. I've already tested the Sci comunication and my matlab script and they don't have any issues. I'have also tested with a DC input instead of sin waveform  of 10Hz and works just fine, so I' have no clue whatsoever.
    Here is a picture of what I get when I sample a sin coming from a signals generator.
    If anyone has any idea it would be really helpful. This is for a project that intends to get an EEG signal.
    Thanks for your time, regards
    Albert
    ads1298 sampling problems
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Tom Hendrick
    Posted by Tom Hendrick
    on Aug 12 2012 08:10 AM
    Guru86200 points
    Hi Albert,
    When sampling the ADS1298 at 500SPS using only CH1 for data conversion, you'll need to read the 24-bits of the status word and 24-bits of the conversion result with every instance of the DRDY signal (2ms at 500SPS).  With your 1MHz SPI clock, you should have plenty of time to read out the 48-bits.  Are you using the DRDY as an interrupt to the HC08?  How are you controlling the /CS input to the ADS1298?
    Tom
    Report Abuse
    • Reply
  • Alberto Tablon
    on Aug 12 2012 09:59 AM
    Prodigy60 points
    Hi Tom,
    I'm using de DRDY as an interrupt, with the input capture peripheric of the micro I generate an interruption every falling edge of the DRDY signal. I've configure de AD in the RDATAC read data continous mode. I control the CS pin of the AD with an output of the micro that is always set low. I've tested the DRDY signal in the osciloscope and it seems just fine. Here is a stream of samples that I get from the AD in hexa:
    (2 samples)
    C0
    00
    00
    1F
    E6
    94
    00
    00
    00
    C0
    00
    00
    00
    47
    62
    00
    00
    00
    The first 3 bytes are from the status, the next 3 are from the channel1 and last 3 from the channel2(which is shut down). Every 9 bytes we have a sample from the AD.
    Could be a problem with the spi?
    Thanks tom for your time. Regards
    Alberto
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 12 2012 10:19 AM
    Guru86200 points
    Hi Alberto,
    This looks reasonable I suppose - I can't comment on the validity of the conversion result since I don't know what the analog input was when the conversion started.  Is it possible to get a screen shot of the DRDY interface showing the SCLKS and your SDI/SDO?
    Tom
    Report Abuse
    • Reply
  • Alberto Tablon
    on Aug 13 2012 12:58 PM
    Prodigy60 points
    Hi Tom,
    Here are the osciliscope scopes:
    This is the SCLK (green) and the DIN (purple) this is the MOSI (the master is the HC08), I'm sending a 0x00 through the spi interface towards the AD
    Here is the SCLK in green again and the purple signal is the DOUT
    This is the same scope but a bit closer:
    If you see a problem in the spi comunication please let me know.
    Here we also take a picture in matlab of a square waveform of 1Hz and Vmax=1.5V Vmin=1V. There is always a problem when signal change of value:
    Thanks for your time. Regards,
    Alberto
    Report Abuse
    • Reply
  • Tom Hendrick
    on Aug 14 2012 08:26 AM
    Guru86200 points
    Hi Alberto,
    Is the MatLab waveform conversion results from the ADS1298?  Where is all of the overshoot coming from in your scope captures?  I suspect you either have grounding problems on your board or you don't have the ground lead of your probe connected.  SDI and SDO both appear to be going nearly 2V negative, so you'll want to take a look at your wiring as well.  Is the ADS1298 on the same PCB as your controller or are you fly wired between two boards?
    Tom
    Report Abuse
    • Reply
  • Maximiliano Cordoba
    Posted by Maximiliano Cordoba
    on Aug 26 2012 10:50 AM
    Prodigy40 points
    Hola Alberto
    Que bueno encontrar a otro argentino en este foro!
    Te cuento, yo estoy usando este integrado en dos placas diferentes. En ambas veo una fuerte influencia del ruido ambiente de 50 hz, lo cual complica muchisimo las mediciones. Actualmente, estoy tratando de implementar algún filtro digital de 50 Hz para ver si mi señal no se está ocultando tras ese ruido enorme.
    Cuando tuve problemas similares a los que comentaste vos, los solucione referenciando la masa del integrado con la del lugar donde queria hacer la medicion que deseaba hacer, esto es aplicable solo si usas fuente partida. Por ejemplo, cuando lo probaba con un equipo generador de ecg, tuve que poner un cable que una las masas de los dos equipos. Cuando probe con una persona, uni la masa del circuito con un electrodo a la pierna derecha (en mi caso no tengo implementado el circuito driver RLD).
    En mi caso nunca tuve problemas con la comunicación spi. Probaste con las señales de testeo internas?
    La verdad que estaría muy bueno que intercambiaramos experiencias con este Integrado, cualquier cosa comunicate conmigo via email.
    Saludos cordiales
    Maximiliano
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
