Is it true that the thermal pad of AMC7812 should be connected to analog ground?
Zhu
Hi Zhu,
On the PQFP ad PVQFN packages; the thermal pad needs to be soldered to the PCB. On the AMC7812EVM, the thermal pad is soldered and connected to AGND. The layout plot below shows the AGND and DGND split plane on the AMC7812EVM. The recommendation is to connect the Pad to analog ground.
Luis
Howdy user3681320,
The EVM design files are attached to this post. I believe they were created using Altium.
Matt
Consider checking the "Verify Answer" button if I've answered the question to your satisfaction.
